I see there talking about Grounded Load, but can't find anything about Capacitance problems.
you'll agree thou we are talking about 2 different animals .one will be different better of worse than the other for our needs.unfortunately these pdf's are not targeted at pi metal detectors.
in different pi designs some coils are connected to v+ like in the hammerhead and to v- in the surfmaster.whats the consensus on which is best ?
i'm here to learn thats all.
if the coil is connected to ground and the sheild is connected to ground might the capacitance be less ?
Less than what? Where do you find any PI@ where the coil and shield are not connected to ground?
Your original question was not whether to connect the coil to ground, but whether to connect the coil to B+ or B-. (Isn't that what you really meant?)
In the vast majority of cases that answer simply rests on whether using N or P devices because that will determine whether B+ or B- is connected to ground.
