Originally posted by der_fisherman
View Post
IGSL
Very good silverdog and thanks to Ivconic too.
I hope i can get one IGSL kit for my homemade coil (Tesoro coil)
Nelson
Originally posted by silverdog View PostBack from my summer holiday and IGSL boards are here
As previously stated they are a pair of boards with a snap off groove between
One board for each coil type
They are in my shop now
Kits will be added in a few days
thanks again to Ivconic
Silverdog
IGSL with musketeer coil
I built the IGSL, and I tried to duplicate the musketeer coil. I used Ivconics original coil form, and get 1.01 mh for transmit coil, and 14.73 mh for receive coil. I got it to work, the discrminate works two tone... but the depth is terrible! 4 inches for a quarter! Ive tried adjusting the Tr. transistor, and tank circuits with different caps. -but still no good. This thing acts like its running on 1/4 power. Has anybody duplicated the musketeer coil and got it to work good, if so please post the details. If I cant get this fixed , Im going back to the original TGSL coil & osc.circuit!
Originally posted by Wiltran View PostI built the IGSL, and I tried to duplicate the musketeer coil. I used Ivconics original coil form, and get 1.01 mh for transmit coil, and 14.73 mh for receive coil. I got it to work, the discrminate works two tone... but the depth is terrible! 4 inches for a quarter! Ive tried adjusting the Tr. transistor, and tank circuits with different caps. -but still no good. This thing acts like its running on 1/4 power. Has anybody duplicated the musketeer coil and got it to work good, if so please post the details. If I cant get this fixed , Im going back to the original TGSL coil & osc.circuit!
What is happening if you try to balance it bit by bit and at the same time check air depths with coin? Is it improving or not?
Would be best if you have some original Musketeer coil to check the rest of electronic.
That's how you will clear up any doubts that there is something bad on pcb.
Can you lend coil from somebody?
At 2 IGSL's i made so far i hadn't depth problems. But in the past, making many TGSL's i had similar problems and in most of the cases it was only because of not so good nulled coil.
Selim,
you did great, it looks good and easily adapted to most enclosures......thanks.
(I must admit I never realized that we had so many "Pots"....I only counted P1 to P4....the rest are usually "set and forget", or at least I was hoping for that.......can you elaborate for me please?)
Andy
Originally posted by Qiaozhi View PostWhat software did you use to create the front panel design?
BTW: can anyone explain how the two GB channels might be put to use for hunting?
(I guess you could use one to hunt for ferrite by intentionally not ground-balancing???)
