IGSL
    ok 22:17 o´clock in germany
    have to work tomorrow
    last result
    resoldered 3 of my pots - first test run - blew one cap 220uf25V wrong poled
    checked my coils before testing - oh no after glueing them and tighten/covering with tape they drift from 14,7mH and 0,98mH to 12mH and 0,8mH
    next try next weekend good night
    thats like this
    http://<b><u>http://www.omfg.to/watc...-eier/</u></b> sorry
    (ps i love pi coils)
    OUUUCCHHHHHH!
    Even i do feel the pain here!!
    Stupid girl and 10 times more stupid boy!
    They should be married by now!
    "..ps i love pi coils..."
    You are not the only one!
    • Hello Silverdog
      Today I received my order from you, Belden, potentiometers, speakers, but not 2 games IGLS pcb
      You are also wrong that my Address proper command to your pm.
      • hello
        on my board i used a BC 547C instead of BC 547A (i think normal) because it wasn´t in the kit. now i compare datsheet i saw that the c type has higher gain - so it is stronger should this make some problems in future when my igsl finally works?
          hello
          Should not make a big difference, i think.
          • Tune up aid
            All, I recently got my Tx on frqeuncy tweaking the coil an caps.
            I now need a 16.3kHz source to provide a constant amplitude signal to enable me to quickly tune Rx coil / caps to 16.3kHz to give biggest Rx signal thru Rx chain..
            Thinking of a digital watch they have 32.768Khz clock, the sharper amongst you will have realised that if you divide this by 2 you almost land bang on.
            You can get a watch xtal for $0.40 or a complete 32kHx oscillator for £1
            A dual D type FF will do the '/,2
            I got some bit on order if usefull I will post data.
            The flip side is waving coins all night ,,,
              A good inductance and capacitance meter is worth getting for this business. Then just calc the required capacitance and verify by meter - is easiest way.
              But your way would be good too if you have patience.
              Here is another possibility -- put your RX coil instead of TX in the oscillator, and put .015 uF cap instead of .022 uF cap in oscillator. Then adjust the .015 uF cap until oscillator frequency is approx 16.3 kHz. You will be very close. Or more accurate is to calculate the final value as:
              Crx = Cx * C1 / (Cx + C1)
              Where Cx is your tweaked .015 uF cap combo, and C1 = .22 uF.
              Crx is the capacitor you need in parallel with your Rx coil.
              • Tune up aid - £2.50
                All this is the 16.3kHz crytal controlled tune up aid I used for my Rx coil cap combo.
                Best of all its less than £3
                http://i944.photobucket.com/albums/a...e-ola/unti.jpg
                Steve
                • Easy way to check a frequency against a known frequency
                  Hi Guys,
                  I just remembered something from my school years about Lissajous figures and Oscilloscopes, so I looked it up on the web and found a great site here, do have a little play to see how it works, use a 90° phase difference at first:-
                  http://www.magnet.fsu.edu/education/...ous/index.html
                  Whether or not we can use this or not to set up an oscillator in an MD or not I cannot say for certain as my scope's X-Y function does not work..
                  My thoughts were to use a frequency generator, there are free software ones for PCs on the web (like the one described by Don Bowers in TGSL 101.), to set up the required frequency and take the other from the IGSL.
                  If the frequencies are identical, you will get display changing between a flat line at 45° to a full circle, when the frequencies are identical are identical. This could be a great way to make sure that your IGSL is on frequency.
                  Don does a similar method, but using his ears to compare the two signals, this should be even more accurate (at least with old ears!!)!!!!
                  Any phase difference will change the X-Y display it from a full circle to a flat line.....
                  Free software signal generators to download are here:-
                  http://www.softpedia.com/dyn-search....erator&x=0&y=0
                  Any thoughts gentlemen? Can someone try it out?
                  Andy
                    Hi Guys,
                    Andy
                    Good for comparing phase of two signals of exactly same frequency. Probably not stable enough to use when two diff frequency sources. For our work, measuring frequency with oscilloscope or multimeter frequency counter should be plenty close enough.
                      Steve
                      Thanks, nice circuit!
                      My problem is multimeter AC volts usually doesn't go to 20 kHz -- more like 400 Hz range. So be careful to check your AC voltmeter frequency range. However, it probably wouldn't make too much error, depending on slope of frequency fall-off.
                      • I agree with simon stateing quote check that you frequency meter is accurate in the post above, and I like to advance on that saying that applies to all test equipment, us engineers regulary check are equipment for accuracy'' well maybe I dont as much as should but thats me im sure most of you do or should do which is quite simple for us because either we have duplicate equipment to compare with, or we know someone who has.
                        Now the point I like to put forward is that a novis or engineer has a meter looks at it like a bible, ie if it says 6.5mh then it is, because its the gospel, there meter/bible told them so.
                        The moral of that situation is, if they got duff test equipment they most certainly would have been better off without it because they would have looked at different angles to get round the situation.
                        You only have to look at some of the threads on here to realise that either some people either cant use the particular equipment, bad eye sight, or got duff test kit.
                        I can personaly say that in almost 40 years engineering in the Radio and TV trade never came across test equipment that couldnt use apart from that heap of crap bought from fleebay in china inductance meter (the one in a blue housing lol) I posted in previous post here.
                        you all know the story of that one with the TGSL coils, and im a engineer, so imagine a newbie in the same situation, you would think they would be knackered up against the wall, but some do pull it off admeration is called for, how some of them make these projects work with the limit of there skills makes my mind boggle, saying that I was quite lucky when i was a kid willed most of my projects to work, otherwise they were on along with my chemistry experiments to burn the evidence.
                        Anyway yet another good interesting topic I take my hat off to you all
                          Do you have a chance just to try it out for us here? Does anyone here?
                          Thanks in advance
                          Andy
                          • I receive today the two PCB (TGSL and Musketeer ) from Silverdog. Pro quality and quick delivery, thanks Silverdog.
                            In a few days I must begun assembling the components.
                              Thanks in advance
                              Andy
                              Check this post demonstrating target phases with lissajous: http://www.geotech1.com/forums/showp...56&postcount=2
                              What specifically do you want to try?
                              • Hi, any ac voltmeter will give you something useful Id imagine
                                Your looking for a relative measure, of how much signal is coming thru - matter of tweaking caps about for max. Works very well.
                                An old AVO 8 will go out 100kHz !
                                The meter I use here is a tektronix DMM914
                                Has a cap meter
                                frequency counter to 2MHz
                                True RMS etc
                                Steve
