IGSL
  • Elko with too much voltage??????
    .....elko with elko but i think its only a problem of an elko with to much voltage
    if i kow if i can replace the one elko with a mkt i would try it......
    .......any other advice welcome
    I will say it again:-
    The voltage marked on an elko (Electrolytic Capacitor), is a value that must not be exceeded by the circuitry where it is connected. If you are expecting say 24 volts max, a 25 volt Capacitor is a bit close, a 50 or 60 volt would be best!!!
    BUT, it will not give any problems if say you have a 50 Volt Cap, in a 10 volt circuit.......
    Its a bit like driving! For example, if the speed limit is 50 KMH, as long as you do not exceed 50 KMH, you are OK. But if you drive at 60 KMH and you will be in trouble with the police!!!!!
    The only difference is that for the same value, for the same type, from the same company, the 50 volt version will be (slightly) bigger than the 16 volt version.....though modern caps are getting smaller as the technology improves.
    Do you now understand fully? Please ask if I was not clear enough.
    Andy
    • ok thx andy
      so wide so clear i understand
      but can anyone tell me if i co the right way to set my tx and rx to the fequency with the caps
      i did i run the wrong way
      • Hi Bernte one, If I have it right - you want to tune your Tx onto ~ 14khz
        And your Rx onto approx 16khz
        You are using a coil with L values outside of the normal IGSL coils design of approx 6mH.
        Steve
          Steve
          hello golfnut
          written already above:
          i calculated the frequencies of
          tx 14.001 kHz (ideal would be 1,2 *f rx 13.870 kHz but cant find better caps)
          rx 11.559 kHz
          or did i confused the frequency shft of rx and tx
          should rx be 1,2 of tx? i thought it were other way - is that my failure
          coil that i have has 0,38 and 0,71 mH
          • Coils question
            Apperas to be some confusion as to what Tesoro coils can be used with either the TGSL, IGSL-Tesoro, IGSL-Musketeer.
            Any one make a short list of which coils are compatible, 4 pin, 5 pin......?? This would be very helpful for those who cannot build their own coil.
            • Not sure what part on PCB marked 334 is??
              Looks like a cap but, not 100% sure on the value.
              • Capacitor conversion and codes
                Its a cap in Picofarads 334 = 33 and 4 x 0(zero) = 330000 pF.
                OK?
                Andy
                PS. If you look around on the web there are simple tables around to download that help you to convert such a value into say nano Farads for ordering....
                Look here:-
                http://www.justradios.com/uFnFpF.html
                http://www.turretboards.com/capacito...sion_chart.htm
                http://www.calculator.org/property.a...me=capacitance
                http://www.radio-electronics.com/inf...sion_chart.php
                • Originally posted by SVEN1 View Post
                  normally the 5 pin tesoro (older models) with tgsl
                  the 4 pin newer coils with igsl musketeer
                  but cant say you which minelab coils without modifying the tx and rx caps
                  my excelerator 2 with 0,38 nad 0,71 mH works not
                  the supersearch coil for my old musketeer x cant work it has something of 1,1mH and round 20mH
                  the diy coil i tested works good 1mH and 14,7mH
                  i thought i give it up to make diy coils with so much windings and maybe also vlf detectors building coils or modifying original ones takes too much of my time
                  i think i wil concentrate to pi detectors coils are more simple
                  maybe i use my excelerator 2 with one of my pi machines
                  • bernte one..
                    The Tx on IGSL is 14.6kHz (it is on the schematic)
                    The Rx is 16.3kHz ..... ( from 1/(2 x pi x sqrt(LC)) L was 6.5mH C is combination of C4 and C43 (4n7 and 10n (which is 14n7))
                    So in this IGSL OFF resonance design .. Rx coil and cap is 1.7kHz Higher than Tx.
                    You are right about the ratio of Tx to Rx being approx 1.2 (actually 1.116) BUT, Tx is lower, and RX is higher.
                    For you to resonate your coils at original IGSL design frequencies - with your Tx coil at 0.38mH and Rx coil at 0.71mH
                    With standard values
                    C1=3u3
                    C2=330nF
                    Gives a Tx of 14.9kHz
                    C4 = 100nF
                    C43 = 33nF
                    Gives an Rx of 16.4kHz
                    Difference of 1.5kHz This should be fine.
                    steve
                    • @Golfnut,
                      I think there is a mistake.
                      330nF with 0.38mH gives 14.21 Khz (not for C2 but for C1, C2 is for 9V filtering).
                      And guess what, 14.21 Khz multiply by 1.166 gives 16.56 Khz just like 130nF with 0.71mH.
                      but the real frequency will be 16.37 Khz with 133nF (100nF + 33nF).
                      With a manual selection of the caps, you can easily reach the correct value.
                      Hugo
                      • Use this to adjust Rx coil! It`s easy to make and very accurate.For transistors you can use any type like BC547 (NPN) and BC557(PNP)
                        • @Bernte_one : Try this http://www.deephaven.co.uk/lc.html to calculate your capacitors.
                          • Hi Hugo, If Bernte one is using an IGSL, I am right.
                            If Bernte one is using the schematic in your post YOU are right.
                            S
                            • Originally posted by Pompey View Post
                              As I am not a Russian expert, it would be very nice if youcould write a few lines about how it works/is used etc..
                              Thanks in advance
                              Andy
                              • Hi Bernte one this is the schematic I was working with
