Arduino metal detector?
  • #31
    I'm trying to make one VLF with arduino due benefits are more interesting I consegir drive a TFT LCD touch my siquiente step is to manufacture the coil to work at four frequencies at the same time 4khz 24kHz. My double D coil will ohn I am with design
    • #32
      Multifrequency? Why not. If you go with the BBS Tx excitation, you'll be able to process frequencies sequentially.
      • #33
        Originally posted by joop View Post
        Anyone tried using an Arduino board to build a metal detector? Thinking about a pulse-induction type detector, like Andy's Chance detector.
        Would be nice as an open source project, with the code to be downloaded and modified to your needs. Maybe even with a custom arduino shield.
        Hi Joop....i would like to have a go at arduino to programme a lcd bar graph for a pulse detector...ive never done programming before and im very slow at learning this type of thing !!! do you think i could learn to do this ????
        • #34
          Here is a link to the Foxy PI Arduino metal detector, looks interesting, but the power supply arrangement looks a bit unusual
          not sure about VR1.
          http://acdc.foxylab.com/node/47
          Hello! Thanks for link to my project.
          VR1 - DC-DC Boost Converter Step Up Module 1-5V to 5V 500mA Power Module New F5 from ebay
          • #35
            Hi Foxylab thanks for the information on VR1, yes lots of modules on ebay, should there be a connection to VIN on the nano board ?
            where do we download the software thanks ?
            Would your software work ok in Arduino UNO wihout any modification ?
            • #36
              No, not to VIN. Output of VR1 must be connected to "5V" pin of Arduino.
              where do we download the software?
              Software currently in development, very-very old version (without menu, interrupts etc) can be downloaded from my GitHub : https://github.com/Dreamy16101976/foxyPIv1
              I will upload new version in the future.
              I will be studying this problem.
              • #37
                Hi Foxylab
                Thanks for the information, I have copied the sketch, and added the extra libraries from adafruit and jeelib
                the code compiles, but does throw up a warning about one line of code, but as you say its very very old.
                Cheers
                • #38
                  Field test and search with my Arduino pulse metal detector 26.03.2016
                  https://youtu.be/Xk4X6O1646M
                  • #39
                    My Arduino pulse metal detector: dynamic (motion) mode in action
                    https://youtu.be/LoBzFpZ0NYw
                    • #40
                      I researched the loudness of my piezo element at different frequencies. As well as draw in datasheet, characteristic of very chaotic. However, I have found a series of frequencies 800 - 900 - 1000 - 1100 Hz with increasing volume (according to Android-application - from 54 to 69 dB).
                      • #41
                        My Arduino-based MD in action:
                        • #42
                          can we make separate threads for simple pi of Alex (narod.ru)
                          and another thread for foxy pi?
                          i would do active work on both Project, Goal is to create a layout for easy shield pcb for arduino nano
                          best regards
                          • #43
                            My new finds:
                            Guess what it is?
                            • #44
                              Some sort of cannon projectile ?
                              • #45
                                Yes, fragments of mortar shell (IMHO german 81,4 mm).
