Arduino metal detector?
    Nice simple PI detector.
    The first result of the first garden search with FoxyPI v3.3:
    • Interference from LCD TV:
      • Firmware for testing of FoxyPI v3: https://acdc.foxylab.com/sites/defau...aloginputs.hex
        In test mode, the metal detector generates a current pulse with a duration of 150 μs in the search coil after switching on, and then it displays the received signal on the screen. Pressing a button generates a new impulse, etc.
        Examples of signals:
        1 - without target, 2 - with target:
        • The result of the second garden search with FoxyPI v3.3:
          • Originally posted by FoxyLab View Post
            Thats very interesting.
            • Here is what I found with the FoxyPI:
              Weight: 100-150 grams
              Volume: 15 cu. cm
              It has magnetic properties.
              The surface does not conduct electrical current.
              • What do you think it is ?
                  Meteorite???
                    Meteorite???
                    If its a Meteorite, get it professionally assessed it could be worth a lot of money
                    • Looks like maybe a hematite nodule. Do a color test on a unfinished peice of porcelin like the underside of a toilet tank lid.
                      If the color is brown or brownish red its more than likley a hematite nodule.
                      one way to tell a metiorite is the surface will have concave formations where the hematite has protrusions or nodules.
                      • Originally posted by godigit1 View Post
                        Looks like maybe a hematite nodule ...
                        Very thanks for information!
                        • Streak of my find:
                          Hematite?
                          • Hard to tell but looks more like magnatite.
                            When you say has magnetic properties. Is it magnetic or attracted to a magnet.
                            If you had a local goelogist, would not hurt to ask him.
                            Their are shots of color streaks on the web you might be able to see the colors better. But hematite is usually browner than what i see in your picture.
                              yes a simple stick on pcb, where you can stick the arduino nano direct on with the pin headers, so that there are no loose wire all around
                              that configuration would be great, as it makes building a pi pinpointer easier.
                                Yes, a strange stone. Still, his streak color is far from the gray-black, which is characteristic of magnetite.
