Does anyone have a good sub for the LM389?
  • Does anyone have a good sub for the LM389?
    I decided to build a BFO before I started in on a more complex device. Downloaded the .pdf from here ( http://tthn.com/geotech/metdet/bfo/edn.html ), and hit a snag right away.
    The LM389 is a discontinued semi-conductor. No sub listed in the current ECG or SK cross references. Any ideas?
    TIA,
    Scott
    Re: Does anyone have a good sub for the LM389?
    the national data book says it is just 3 npn transistors and an audio power amp similar to lm386----get a 386 for the audio and use descrete transistors with similar specs. as those listed...
    you will not have the 18 pin pcg. but should not be an overwelming obstical...if you still have troubles--repost---maybe someone has a 389--me
    will look some but doubt it--
    reg-rick
    >TIA,
    >Scott
      you will not have the 18 pin pcg. but should not be an overwelming obstical...if you still have troubles--repost---maybe someone has a 389--me will look some but doubt it--
      reg-rick
      ps:me no look at schematic but the thermal drift
      of xisters ----look at lm4046 or similar as all
      xisters same substrate--closer match---but still
      better can be done--dual fet etc...
      reg-rick
      >TIA,
      >Scott
        ps:since a trouble on 389---a dual fet for oscillators would give better preformance because of high z-in and temp. tracking... but it seems you do not want to have maximum results---just get to work---
        reg-rick
        >reg-rick
        >>TIA,
        >>Scott
          Rick is correct, use an LM386 with discrete transistors. Simple 2N3904's should work fine, matching is not really critical. Thermal stability will probably suck no matter what transistors you use, but use good caps (polystyrene or polypropolene) to minimize thermal drift.
            Thanks guys, sounds like this is more my speed for now +
            I saw the reference to the lm386 my fourth time through. I will be happy to have a submersible PI unit running by May or early June.
            S
              sorry scott--looked some no find though--rare one. but did a search with dogpile and go here---
              http://www.dialelectronics.co.uk/l5.htm
              looks like they have/had this.
              reg-rick
              >TIA,
              >Scott
