pcb
  • pcb
    hi carl-
    tried out that iron on transfer film for
    making pcb..that stuff is interesting
    and a lot less effort than the photo
    techniqe...got it on the first try---
    with the iron set low temp--had a sheet of
    teflon film to use in btwn. in case of
    iron sticking--it was not required..
    too bad the dreaded pen is required in a few
    places---but not too bad--
    did not expect the blue to go with the toner--
    interesting to use the toner as an adheasive..
    did try a little hotter--phenelic warped a little
    and cu got a little discolored under blue/no toner
    what software did you use to generate the artwork
    and laser printer--600dpi--mine 300
    just a words- to make pcb with pads as a surface
    mount type--bend pins in on std. dip at the knee
    and solder in place---save much time less drill.
    except feedthrough (could bend pins out also).
    do same for resistors etc...practical approch.
    reg-rick
    Re: pcb
    The key to success is clean, CLEAN, CLEAN!!! Then don't touch the copper surface, & make sure there are no edge burrs.
    Yes, I've noticed this too.
    600dpi, although my 300dpi is pretty good.
    Yes, surface mount is easier, but I like to socket my IC's, esp those $24 ones.
      Re: thanks again n/t
      >- Carl
        Re: pcb
        Fat Quarters Software (me and Laurie) are having some PCB's made. They'll be ready in a week; by Oct. 22nd. All the holes will be drilled too! See the last page of Carl's article for details.
        Erich
        >- Carl
