IDX-PRO+VDI
  • PP = P/P = all metal different way to say the same P11 short in ID-IDX_SCH_FINAL_505-0210-D.gif
    Connections are in post 576 here
    GEB and Theshhold work in PP mode
    • [QUOTE=Koala;179545]CCW and CW = counter clockwise and clockwise
      Thanks for the explanation de acronyms!!
      Dirk
        thanks man
        but my means my RX when lower than 200mv speaker continue have sound
        u say me THERSHHOLD and GEB for pp point ,ok but how i adjust pp point
        first i near a little foil and change GEB pot and dont reject it,why?
        i know my detector is work but i cannot adjust it
        • Lets do one at a time.
          In PP (P11 short) and theshold fully clockwise there should be a tone from the speaker. Turning the pot counter clockwise until the noise just goes this is a good setting for detecting in PP mode
          Two
          To set the GEB (ground balance) turn the threshold up a small amount so there is a small noise from the speaker. Wave a small piece of ferrite 2" from the coil. The sound will either go louder or quieter adjust the GEB until the sound does not alter
          Three
          Remove the short from P11 the detector is now in discrimination mode (disc). Turning the DISC clockwise and wave a small iron in front of the coil until there is no beeb from the speaker.
          This is a very basic setting Golfnut gave a much more detail explanation a few post ago.
            Two
            Three
            Hmmm
            it is excelent , but befor do this all pots are in middle ??????????
            Turning the pot counter clockwise = P5 or sens pot 100k ,correct???
            ok i have not ferriet can use magnet ??
            i adjust my detect by your good and simply guid ,thanks
            i adjust and put it here my result
            depth of detecting is very bad ,can detect 4.5*4.5cm foil in 17cm(befor adjusting)
            thanks
            • I run sens pot fully clockwise. This gives max depth. If the detector becomes unstable then turning it counter clockwise slightly.
              aluminum foil 4.5*4.5cm with a 8" coil 24cm depth in DISC mode
              If DISC, GEB, TRESHOLD and PP are working then you may have to adjust your RX capacitor.
              post 5264 here
                post 5264 here
                hi
                ithink my problem in ne5534 - pin6
                please see the pics , BLUE color for all is pin6 ne5534
                1-ref TX
                2-pin1 U8
                3-pin7 U8
                my third file this site canot upload.
                please tell ebout the pin6 ne5534,is it ok???
                • You have a large DC offset at the preamp output of at least +3.5 volts.
                  That why the Rx signal looks clipped - its saturating on the pos rail..
                  This needs to straddle the 0V position
                  Make sure the rails are +4V and -4v WRT the copper around the cct board edge.
                  I dont know what you have done here to get this.
                  Put some good 2Mbyte images up in good focus with natural light and we will all try to help you
                  You could force a better DC offset condition like this...
Name:	offset correct.JPG
                  S
                    S
                    OH
                    man i frist say all i get 6.42volts in WRT point.(pin7 U6)
                    i check power supply and all component is ok , no short circuit,so where is wrong??
                    just i replace 7808 instead 2930.
                    http://www.geotech1.com/forums/attac...4&d=1380330021
                    • Post some good quality photographs will help. In post 1876 the detector was working if not 100%. In post 1883 you modifyed the board to be like Dixix I advise you to go back to the original it works fine and is proven to work. With a good home made DD you will get very good depth. You can always experiment and modify it at later date.
                      • Originally posted by mohandes View Post
                        OH
                        6.42V ? what are you using as the ground(GND) point
                          my friend
                          my lm358 have error(maybe chinese)i change both of them and know work well(just low depth , i will set it)
                          thanks again for you Mr and Mr golfnut.
                          i will try to best adjust that you tell me
                          i have not ferrit can use magnet ?
                          EDit:
                          for adjust i first short pp and fully trshhold on CW and then speaker have a big tone i do not touch more.
                          then i set Geb pot by frite until cannot detec it
                          then remove short of pp then by disk can set reject iron.
                          sens pot for depth,when i CW or CCW not change more and not good discrimination
                          thanks
                          • Download http://www.2shared.com/file/8R4fXSTl/PCB-IDX.html
                              my friend
                              EDit:
                              thanks
                              Ferrite can normal be found in broken power supplies, on the end of some cables(the bit that bulges), inductors and old radios (long wave or medium wave)
                              Set THRESHOLD with PP short so you can just hear the speaker. Then set GEB with ferrite.
                              SENS pot fully one way will have slightly more depth than the other.
                              With PP open. DISC turn until iron is rejected.
                              If everything works as it should but depth is low try experimenting with different RX capacitors.
                                thanks
                                frist i should go and by 5cm ferrite,
                                and next my result here
                                so thanks
                                see you later
