IDX-PRO+VDI
    hello
    i have seen vdi board at silverdogs shop
    he wrote it can be adapted to igsl/tgsl
    but how
    is there any conection sheme out
    can be that this vdi board is connected for all units same way but i dont know how
    or can it be connected to original musketeer???
    thx for any answer
    Check Ivconics post #194
    • Originally posted by holyuser View Post
      You must calculate the value of the resistor so that a fully charged battery at the entrance of the processor (pin 2) is 3.1738 volts, if VDD is exactly 5.000 volts
      Apologies for a dumb question
      If I put kits together what range of resistors should I supply for R2 ?
      • Hi Holyuser,
        What do you think about using one or several ports RA5/RA6/RA7 of the VDI µP to drive an audio stage ?
        In exemple :
        - below 0; all outputs set to zero.
        - between 0 and 10 : RA5 set to 1
        - between 11 and 30 : RA5 and RA6 set to 1
        - etc ...
        With a BCD decoder, you can even have up to 8 command lines ... meaning 8 differents tones !
        It will be fine if the user can choose the number of thresholds and the values of them.
        But it's just an idea ...
        • Originally posted by hugo View Post
          Hi Holyuser,
          In exemple :
          - etc ...
          Hi Hugo,
          - RA5 is input only, not possible to be used as output;
          - RA6 and RA7 are reserved for external crystal resonator;
          - RB0 is left free to be used for sound or TX drive, but that will be possible if PIC runs at 16 or 20 MHz.
          • @Holyuser :
            I don't know the mode the µP is running but in INTIO2 mode OSC1 & OSC2 can be become RA6 & RA7 working both as digital I/O.
              I mean, that RA6 & RA7 are reserved in my project, not generally.
              There is resonator connected in my PCB - look picture at post #19
              • @Holyuser :
                Ok, I understand.
                So, I will say it differently ... Can we imagine a special version of the VDI, closed to the original schematic (without an external oscillator), able to pilot the audio ?
                What do you have into your brain ?
                • Originally posted by silverdog View Post
                  Value of R2 depends of battery type, Vdd and R1 precision.
                  You can calculate it using the equation:
                  , where:
                  Vbat - is voltage of the fresh battery used (in Volts);
                  Vdd - is microcontroller voltage supply (in Volts);
                  R1 - in kOhms
                  In example, if You fresh battery is 12,6V and Vdd is exactly 5,0V and R1 = 20 kOm, then Your R2 must be:
                  You can use in this case 6,8 kOhm resistor, I think...
                  • Apologies, more dumb questions
                    I guess if your R2 value is incorrect the only consequence is inaccurate battery display ?
                    Could you explain the formula in steps I can't see how you get 6.7K from those values
                    On the Schematic there is no value for C1
                      Yeah, right!
                      In the present example, would be like that:
                      1. we must firstly calculate 1024x12,6=12902,4 and 650x5=3250 ;
                      2. in the next step we find 12902,4/3250=3,97 (approximately) ;
                      3. next, we can find denominator as 3,97-1=2,97
                      4. finaly we divide 20 by 2,97 and voila! 20/2,97=6,734 (approximately)
                      This question is not to me, because that C1 is not part of VDI, but...
                      I think, that something about 1nF would be good.
                      In my opinion, this capacitor is used to reduce the influence of cable.
                      • Hi to all
                        This link is my new vlf project. I used atmega8 microcontroller.
                        http://www.lugatek.com/forum/index.p...sg1416#msg1416
                        For only video:
                        http://www.youtube.com/watch?v=5CAqCVR03KE
                        I will share all documets of this project very soon too.
                        • Attached Files
                            Thanks Holyuser!
                            • Thanks Holyuser!
                              • VDI+HEX
                                Here is all.
