Here is code examples using Proton PicBasic compiler, but I belive they are understandable: http://www.picbasic.ru/forum/5-1709-1
IDX-PRO+VDI
Thanks. It has been a long time since I used basic.
Is this display a nokia compatible? or is it one of these: http://www.ebay.com/itm/Blue-0-96-in...-/141494092860
Originally posted by mohandes View Posthi
idx is vlf detector.so what the def between vlf and bfo?
VLF is a name given to the the low frequency versions of a type of detector, often called T/R (Transmit and Receive), which use two coils, one overlapping each other.
One transmitting the output of an oscillator, the other receiving this signal, but it is so overlaid on the transmitting coil, so as to reduce the size of the received signal, you could say, it being in a "null" position or as near as possible.
If any metal target comes near to this oscillator signal from the transmitting coil, the signal gets distorted and the receiving coil picks this up. The frequency may change slightly, due to the different effects of certain metals on the oscillator signal even. An indication as to the type of metal.
Depending on the complexity of the receiving circuitry (the price of this detector is affected strongly by this complexity!), the type of the metal of the unknown target, its size and relative position and depth might be indicated to the user, allowing possibly a decision as to whether its worth digging up or not!!
Its like comparing a model T Ford car and a Ferrari really!!!! Both are cars, but many years of development separates the two!!
There are similarities to anyone who understands electronics, but for the normal user with little or no understanding of the electronics, this will not be obvious to him at all....
I hope this explains the differences for you in a manner that you could understand, though I have "glossed over" much detail.....but your question suggests that you are not electronically inclined, so I have hopefully addressed the answer in the same manner for you.
Andy
Originally posted by der_fisherman View PostBFO is usually a simple design, using two oscillators and a single search coil. The user "hears" the difference between the two oscillators and can make a guess about the position of the hidden metal, usually called the target. They are generally speaking, not very good in depth and cannot distinguish between different metals. If not set up correctly, the user will often miss even quite large metal objects. A lot of practice is needed with such an MD.
Andy
i read before this PDF.i just search for type of detector completely .IB and VLF is same and good disc....
Metal Detector.pdfbfo.pdfeti549au_300.pdf
IB is VLF?
Yes it is, but there is possibly a significant difference in frequency!
An IB or T-R could be a much higher frequency than a VLF, which works in a similar manner, but many believe that with the VLF design, the target can be better "analysed" and indicated.....
Which is why I "glossed over" such points, to stay within the "BFO and VLF" question.
Andy
