IDX-PRO+VDI
  • Originally posted by elbombaci View Post
    Hi to all
    My new project completed. Its name DM-1. (Discrimination Module)
    Click to this link for DM-1:
    http://www.lugatek.com/forum/index.php?topic=217.0
    For video:
    http://www.youtube.com/watch?v=u6SoCvBTjV4
    I attached all documents here.. But You follow lugatek forums for updates.
    Best Regards.
    These are correct. But... What type of rotary_pot must I buy? :-)
    • Originally posted by Hannu View Post
      What is type of "POT1 ROTARY_POT"?
      Hannu
      Sorry! I didn't see You question...
      • Originally posted by szucs_g View Post
        .......As against a slider pot?
        What is also important to know is Log or Linear versions......
        Andy
        • Hi
          I used this rotary encoder pot:
          http://i1226.photobucket.com/albums/...4/DSCI0064.jpg
          I don't know its type. Rotary encoder pots are not linear or log. Rotary encoder pots generate clock pulse.
          http://www.google.com.tr/search?pq=r...w=1280&bih=685
          I am using rotary encoder pots on my other projects.
          http://www.lugatek.com/forum/index.p...sg1216#msg1216 (This project is LPG level indicator.)
            Hi
            Rotary encoders are not pots. But they can be used to encode a resistance when correctly used with other components.
            As the word encoder was not previously mentioned, it was difficult to help.
            Now its cleared up properly.
            Andy
              I tell You, my friend, the type is ED1112S-20.
              http://home.comet.bg/datasheets/Buttons/ED1112S-ok.pdf
              • elbombaci
                would you mind explaining the connections to the encoder thanks
                • thank you very much for your reply MR Orbit ;my dear friend as far as i can see , there is no mentioning of feed back loop in the post witch MR ivconic has made, can you please tell me more about that and the way it can be connected to IDX and if possible tell me about winding directions of the tree coil and placement of feed back coil (if possible graphically) i apologize for troubling you in advance.
                    elbombaci
                    In Hungary, 24-step encoder can be taken. Previously, I wrote in the web shop are available. There are push-button, which should be here. There will be no problem if you do not pass 20 of the encoder?
                    • No offense. Worked for an obstetrician at the hospital. It was the same last name. :-)
                      • happy new year to you all
                        many many thanks for this great site and your work. great projects, especially this one. I would love to build these detector. I am electrician with basic knowledge and a lot of soldering experience. I've already built the hammerhead and now it is time to deal with something new. I must first see if I get any parts, then I will build a pic burner.
                        I hope you will support me if I have problems ....
                        what alternative is there for the LM2930-8V?
                        sorry for the bad english ....
                        Many greetings and best for the new year, marc
                        • Originally posted by Schatztaucher View Post
                          LM2930(8V)=LM7808. Happy new year.
                          • Originally posted by holyuser View Post
                            Sorry, though I will disappoint you, you cannot remove these in no manner.
                            Never say never
                            http://www.youtube.com/watch?v=d-JH8..._order&list=UL
                            Happy New Year 2012
                            • All your files to download the latest version of the circuit ???
                              best regards
                              • Originally posted by mikipn View Post
                                Sorry, my friend, but you are too late.
                                The next task is you have to remove "Geotech VDI" and insert in its place your greeting. How about that?
                                Maybe you will be able do do it ever to 2013.
                                Happy New Year 2012!
