my silverdog pcb was ok....but it was one of the first pcb´s....without the changes....
IDX-PRO+VDI
How are the performance of IDX-PRO+VDI i.e depth range...
Fe and non Fe metal... And other.....
Low mineralised Europe soil, damp.
Disc set to reject Iron
10" homemade DD Tx at 11.6kHz .. Rx tank 8.5kHz
12.5mm diam lead ball target
4" loud punchy clear tone
5" for clear tone
6" no response
Silver disc 99% pure silver
15mm diam
6.5" weak tone - digable
DISC open to ALL metal
Same test conditions
4,5,6 inches clear loud tone
7" tone digable
8" partial tone - would not dig
9" no response
Silver coin at 6 1/2" slightly louder tone
S
Originally posted by paku View Posti have make DD coil For TGSl
Can I Use It For IDX Pro Or i Need Make New Coil For IDX Pro
I suspect it will air test ok - in use, depending on soil type - you wont be able to ground balance it properly.
The reason it wont GEB properly is that the phase shifter affected by frequency - Change freq and the phasing slides.
So, the GEB will not 'average out the GND signal as it will be sampling or gating the GEB CH mixer/detector at the wrong place in time or 'Phase' - and you wont have enough control range to pull it to the correct phase or gating 'Time' wrt to Tx signal.
- I needed to alter my GEB pot to run IDX at higher frequency - Do a simple model in lt spice and pick a pot that gives you similar phase shift and control range at the higher frequency that the original pot gave at 6.5kHz.
Its a fairly easy tweak and works fine.
I dont know where the recurring wyths come from that your Tx has to be correct to 3 decimal places...
General..
I found I got better sens and usability with the Rx tank on Low side rather than the high side. Theres no good reason for that, just what I got at the time.
If you find it sounding off a lot - The Rx tank may too close in freq to the Tx freq.
A rough guide for delta in freq from Rx to Tx is about 75%
So Tx of 12kHz - - - Rx would be at 8kHz. This should give an easy to use machine with reasonable sens.
All open to discussion and years of relentless to'ing and fro'ing ...
S
Originally posted by pepe View PostI did not read the whole thread so I can repeat. When I start idx'a I found a bug on the PCB from silverdog. It is short circuit X and Y signal:
[ATTACH]24871[/ATTACH]
I will get some corrected pcbs made with smaller pads
I have put this boards in my bargain bin at just £1 each to clear - if you have a knife grab a bargain !
http://www.silverdog.co.uk/shop/inde...product_id=123
Hi all and dfbowrs
When I can find the software or Hex file?
http://www.youtube.com/watch?v=5j_XM0L0BKg
