IDX-PRO+VDI
Originally posted by holyuser View PostDo you like this? http://www.youtube.com/watch?v=xtTIY6zK35c
Excellent work holyuser, congratulation!
How does VDI manage with rotating coin (mean with coin in different orientation regarding coil position)? Does it recognise coin with the same VDI number at the same max. VDI detecting distance with different coin orientation?Attached Files
Originally posted by WM6 View PostHow does VDI manage with rotating coin (mean with coin in different orientation regarding coil position)? Does it recognise coin with the same VDI number at the same max. VDI detecting distance with different coin orientation?
Originally posted by holyuser View PostVDI readings depend on the quality of the analog part is connected. If the characteristics of the two channels x,y (synchrodetectors, filter-amplifiers) are close enough, then the numbers of coins are similar in different orientation and distance, until the maximum distance of detection. Let us remember that VDI measured only what it receives from the analog circuits of the detector.
Did you test how different coil shape (CC, DD, OO ...) affected VDI readings? Which shape is more appropriate if we follow accurate VDI recognition?
Originally posted by WM6 View PostDid you test how different coil shape (CC, DD, OO ...) affected VDI readings? Which shape is more appropriate if we follow accurate VDI recognition?
Maybe in the winter I will do DD for next season.
