IDX-PRO+VDI
  • Originally posted by Leshka View Post
    Help.
    [ATTACH]22377[/ATTACH]
    https://www.youtube.com/watch?v=lyg_Di3kcvU
    • Eduardo1979, I would like to know. Is it correct or not?
        Yes, is correct.
        • My future analogue VDI is now much closer to its realisation. I have a really good 2 quadrant analog divider at hand with all garden variety components.
          • IDX done by eduardo. Coil 25 cm. 1 euro 40 cm when tested in air. Switch is added for 1 and 2 tonnes. I can not insert pictures.
            • Originally posted by Mefisto View Post
              You need to make at least one post before you have permission to post pictures. You've just done that, so please try again.
              • Hi,
                i have a geotech VDI mounted on the IDX Pro. Is it possible to set the VDI Values in a higher range? for example Aluminium is detected with VDI +34 / +38, Alufoil is detected with VDI -2/+2.
                Is it possible to set the Aluminum oder Silver in a higher area ( for example + 85) ?
                • Originally posted by Firebox View Post
                  I suppose that this is not possible
                  • It is the nature of a thin foil to act as a material with very poor conductivity. This feature is your friend
                    • My Lugatek VDI shows a ALuminium Coin with VDI +70 and Alu foil with VDI +38 - +42
                      My Geotech VDI shows a Aluminium Coin with vdi +55 and Alu Foil with VDI -6 - -2
                      My XP Deus shows Aluminium in VDI +90 - +98 Silver in +80 - +89
                      It would be better when both VDI shows approximate the same value.
                      • Do other users of IDX suffer breakthru from large Iron? Small iron I gets disc'd out ok..
                        S
                        • i have the problem with large iron objects. The Disc cracks or give some plops, but my original MiĀ“nelab Musketeer have this problem too. So i belive this is ok ..
                          • VDI signal creep, Help!!
                            I need Help with VDI adjustment!!!!
                            I have finally found an original Whites Blue Max 800 for IDX Pro with VDI. Everything is working fine with large coin detected at around 30cm, plroblem is that as a target gets closer to coil the VDI number creeps either up for low numbers or down for high signal with +45 being the most stable area. An AU 50c will start out at +26 and end up +45 when very close to coil. The Disc pot suffers a bit of creep but not like that! I though these problems would go away with original coil. VDI numbers start to show on screen at about half the distance that audio detection is made, is that normal?? I have scope ect for testing. nobody seems to have had this issue yet,
                            Max
                              I experienced it unfortunately.
                              • Originally posted by szucs_g View Post
                                I noticed the gain endstopping when scoping in XY one time - Rx chain compresses like mad with a tractor wheelnut and goes non linear - the phase dexterity is lost and signals beat their way to the comparator and sound off as would non ferrous.
                                I was toying with the idea of a gain control (AGC) to slash the gain of the front end with large iron signals.
                                The Preamp could have n gain taps with cmos switches to select R's for gain -controlled from an A/D post demod.
                                Similar to ..
                                S
