IDX-PRO+VDI
  • OK, so I have to VR3 make adjustments as the post 178 and adjust VR3 until remove the aluminum foil.
    • 12v battery charger directly to the detector
Name:	2-3-2013 20.3.24 1.jpg
      LM7808.se gets hot and burned by 12v battery charger direct
      • It is best to test your PCB first with all the IC's removed.
        • LM7808.se se calienta y se quema
          remove ic and test voltage joop
          • MPSA13 misfitted
            Error Error revised thanks joop
            • Comment
              • I do understand that the MPSA13 is upside down on the original PCB?
                [ATTACH]23695[/ATTACH]
                • the mpsa13 has the right direction. what speaker are you use? i had the same problem with a wrong speaker......i think i read in one schematic something like 50ohm-speaker.....you came use a piezo-speaker, like in silverdog's kit....
                  • was out of place ,regulator is still hot,Classic 2 Speaker
Name:	5-3-2013 19.3.13 1.jpg
                    • another problem It melts BC517
                      solved was a short another problem It melts BC517
                      • WHAT IS THE OPERATING FREQUENCY OF L IDX PRO ?
                        • Originally posted by ashefr10 View Post
                          It is approx 6.5kHz
                          There is flexibility to move it around, my Tx runs at 12kHz, Rx is about 8kHz
                          S
                          • for what kind of money this detector? Roman? , Gallic? gold? money? bronze? copper?
                            • OK , I'm the cabler different potar, discrimination, treshold GEB ... PP points correspond to a push button for pinpoint? An average value which should make for your R25
                              It is approx 6.5kHz
                              S
                              • my mistake speaker got the wrong cable and invest BC517 is not b
