IDX-PRO+VDI
  • i don´t no....but read this!
    http://www.geotech1.com/forums/showt...4-whites-coils
    • hello, can you replace it with a battery of moist riser card 6 to 12 volts? or you can find on this type of card?
      • My idx depth homemade 10" DD
        There are lots of air test results availble for kits but few in european soil - taking inspiration from dons ground tests I set up a bed. 1" depth increments, short lawn on top.
        Targets are 0.5" diameter lead balls.
        Disc open 7"
        Disc rejecting nails etc 5"
        I will arrange an AIR and add.
        S
        • Hi
          my idx
          http://youtu.be/qr_cKsiySPk
          • hey daxxin....take a look on the coil
            http://www.youtube.com/watch?v=n62sHWQSfvY
            • WOWW!! compliments! , atrleast i know blue deep is working ,but mine not yet
              i hear beep only if i move very fast some metal in the center of coil.
              only turning GEB make some difference ,other pots if iturn left or right nothing change.
              • @ daxxin
                maybe you should post pictures of your board. do you have silver dogs board?
                • hi at all,
                  I want to build my second idx. This time the board with 2 ton.
                  I have some questions for the experts. what to consider? must be changed something at the idx board?
                  and a second question: the sensitivity of the vdi is not very high. about 15 cm for an euro. is there a possibility to improve the sensitivity? which are the best for the vdi connections, on the idx board?
                  i hope somebody has some answers....
                  best regards, marc
                  • Hi, best way to add 2tones to idx is connect it by a switch like in scheme in #1320 at colector of Q3 in this way You don`t have to change anything. 2 tones indicates all metals rejected by discrimination soe use it all time is torture for your ears. I switch from 1tone to 2tone when I found a target, it is very helpfull to identify rusty iron. About sensitivity of vdi it is hard to improve it, i trayed some things but with no result
                    Regards.
                    • ok reiv , thanks
                      • any one have black and white pcb i need that
                        i want try make this IDX look like fun detector
                        • What do you want? Black and white pcb? do you mean the layout....?
                          the layout is in the thread!
                          • yes the layout PCB for board
                            • @ paku
                              check out eduardo´s post #1245. there is his last layout......
                              • i have check the page post #1245
                                but that is open by lay software
                                i need image pcb black and white
                                for print to board
