IDX-PRO+VDI
  • Originally posted by Valters View Post
    Thanks Koala!
    Has someone tried 9V PP3 battery? Working time?
    Normal run time is quoted in the specs of the Classsic III (IDX without display) as between 40-60 hours depending on which site you look at (will depend on batteries used) If you have a display it will be slightly less. Also different make or chemistry of battery will alter the run times.
    Just some figures plucked from the internet but PP3 had 1/4 of the run time verses 8 AA batteries
    Alkaline PP3 565 mah and Zinc carbon PP3 400 mah
    Alkaline AA 2600mah Zinc carbon AA 1700 mah
    So without display you should get about 10 hours
    Would like to hear from anyone who has tried there detector on PP3 batteries to see if the numbers add up.
    • All I can say is "not real long". (How's that for being technical!). Maybe 10 hours without VDI.
      I run two in series and is the only way I have done it. I just don't like the extra battery weight.
      Don.
        Don.
        Nice pictures Don. Did you build the enclosure or re-purpose it from something else?
        If it is from scratch could you give some construction details on building the enclosure? Maybe on it's own thread since it is off subject.
        Jerry
        • The push button is for Pin pointer mode .--- If you look close ate the layout image it says PP for pin pointer.
          • Originally posted by Jerry View Post
            Jerry
            Hey Jerry. It's made from thermoformed plastic, heated and shaped. Same stuff I use for making coil enclosures.
            Don.
            • Originally posted by golfnut View Post
              thank you, but today I tried to turn it on from the audio comes out a strange noise, there is something wrong. try 'to double check everything. I found a plate used the maxima 1500 should be fine if I'm not mistaken
              • hello guys I 'was advised to measure the absorption of energy' cause I have a problem 'if I measure the right things?' cause I do not understand from a value of zero on the multimeter
                • keep the wires to the pots less than 100mm.
                  12v is Normal supply
                    thanks, now shortened the wire potentiometers, meanwhile I made this measurement, and 'normal according to you?
                    • ? The 12V lipo 2200mh sirben for idx + VDI lugatek?
                      • Originally posted by fabio-evo View Post
                        attach a sound file as a Zip will help use understand whats going on
                        • Hi guys today I put a resistor in the kit which unfortunately was not there.
                          I bought the blue max 950 coil from the UK's white, next week is expected to arrive in the meantime I wanted to try to mount the plate garrett euro ace, gave him some signal, perhaps working on it would also work with this model.
                          I have attached a video:
                          http://s740.photobucket.com/user/ven...4b9b1.mp4.html
                          • help ? can put in idx pro +vdi lipo battery 12v 2200mh?
                            thanks
                            • yes i think that would last about 40hrs
                                thanks golfnut
