IDX-PRO+VDI
  • So where is the PARTS LIST for this Board ?
    - It does NOT match the Schematics ...
    For example, What is R46 ???
    • Originally posted by jlsilicon View Post
      I had your problem. I took a photo of the board and printed it out. Wrote each component down the crossed it of the photo to make my own list. Unfortunately I did not keep a copy and the board has changed slightly again.
      golfnut did an upto date schematic awhile back can't search very well at the moment as on a mobile
        R46 is 2,2k
        Carefully read all 117 pages. You will find circuits and circuit boards. Do not expect someone to give you everything for granted.
        • Unfortunately versions with all documentation have now been kept together.
          I am just about ready to wire up the controls and found that picture but haven't
          checked it against my board.
          I have this BOM listed as pertaining to the silverdog board (though there may have
          been 2 different ones);
          • Ok, question,
            I just pulled out my second IDX PRO Kit from Silverdog (I had bought 2 kits last summer).
            I found another new CAN OSCILLATING BUZZER - not a Clicking Piezo.
            Is this what was INCLUDED in the kits ???
            These do NOT make sense to USE - yes ?
            They SELF Oscillate on their Own with only a HIGH DC Voltage ...
            This is already driven by Oscillation fron the Circuitry.
            I should be using a simple PIEZO or Speaker - YES ??
            • Well, I completed the second IDX PRO Board.
              But, still no BEEP or Buzz yet - Nothing.
              Everything connected, Coils and all.
              Shouldn't I get some BUZZ if I adjust the Pots right ?
              • It seems that all components look installed correctly, including Pots, Switches and Coils.
                Are there any Bugs or Needed Mods for the Silverdog Board ?
                  there has only been one bug that was over a year ago http://www.geotech1.com/forums/showt...046#post172046 and was quickly sorted
                  • Found the Parts List :
                    post 1175
                    http://www.geotech1.com/forums/showt...PRO-VDI/page47
                    Is there an image with a finished Board ?
                    - The above image has a portion pasted over.
                    It would be helpful to compare components to.
                    Thanks !
                    • I think my 2 Boards act like dead bricks.
                      I will post Photos of the 2 Silverdog IDX PRO Boards at lunch.
                      Maybe somebody can spot the problem.
                      • jlsilicon you think maybe you have the ones with the short that you need to cut look there first then battery
                        • * I have already scanned over for shorts between components.
                          * I will check for Board Short at lunch.
                          * Battery is (2) 9V Bats in series which should be fine with the 7808 VReg - which is not hot.
                            I believe he means the PCB that was made wrongly, with a short on the PCB that needs cutting. I remember reading about it some time ago....
                            It is documented here somewhere....maybe someone better informed than I can help better....
                            Andy
                            • Board snapshots :
                              Board snapshots :
                              Board 1:
                              Board 2:
                              Coils :
                              Other friend who dropped into my project:
                              I don't see the Short - looks clean.
                              • Can anybody give me a list of Voltage PIN Checks and Oscilloscope Tests - that I can do after work in 2 hours from now ?
                                I have limited time - so a list of things to do would be very helpful
                                - so I can list some info here ...
                                Thanks !
