IDX-PRO+VDI
  • Should make and interesting project holyuser take is you are thinking of displaying some kind of graph with those extra pixels.
    • Yes, there will be a spectrogram definitely.
      • Buonasera a tutti, volevo chiedere agli esperti del Forum, se il prodotto è buono da usare come VDI per IDX-pro che ho fatto, e sono molto felice.
        Display LCD per Arduino UNO MEGA R3 - 1602 SainSmart IIC / I2C / TWI
        Grazie mille e complimenti al Forum .....
        • Where do you get those displays from?
          • www.Amazon.it
            • Originally posted by gtdavid View Post
              If you are talking about Holyuser LCD
              Looks like most are now out of stock
              Can find them in Italy http://www.ebay.co.uk/itm/DISPLAY-LC...d2a1a#shpCntId
              http://www.mytrendyphone.co.uk/shop/...a70-3589p.html out of stock at this one at the moment
              • They seam a bit pricey. .
                • modifications will be made ... for more changes as q LF347N achieved are 40 cm
                  • alguien me puede ayudar con 2 tonos? Tengo 42 cm para una moneda de euro, pero conectando los dos tonos de audio en el primer 30 cm se detecta como debe ser con tono agudo, pero 30 a 42 cm de espesor detecta el tono como si .. ferrosos en lo normal manera sin el tono de ferrita se elimina .. pero el modo de ferrita 2 tonos no se elimina ,,, no que puede suceder ,,, perdona el Inglés utilizar un traductor de google ..
                    • someone can help me with 2 tones? I am 42 cm for a euro coin, but connecting the two audio tones in the first 30 cm is detected as it should be with sharp tone, but 30-42 cm thick detects the pitch as if .. ferrous normal way without ferrite tone is removed .. but how ferrite 2 tone is not removed can happen,,,,,, not forgive the English use a translator of google ..
                      • About the VDI display...
                        Seems like the large one will be better, isn't it?
                        Easy to control, easy to mount on PCB, easy to find and to get it.
                        The type is EADOGL128-6
                        https://youtu.be/oqYIBmBJgUc
                        • Originally posted by holyuser View Post
                          £18 to £25 here in the UK easy to get
Name:	ACHTUNG ACHTUNG.JPG
ID:	343140 ACHTUNG -PAZNJA
                            • Get awake, don't be lost in the past...
                              • yes !
