translation
  • translation
    what does it mean"baterry centet tap"
    Re: translation
    It would help to know which circuit you are inquiring about, but generally that would refer to the common point between two voltage polarities. For example, if you had a circuit that required both a positive and a negative 9-Volt battery supply, the "battery center-tap" would be the location where the positive lead of one battery is connected to the negative lead of the other.
