There are vintage detectors that use many batteries and higher voltages.
For example i would take Cscope 1220B.
It has 2 packs , each one for 6 x 1.5v (or 1.2).
At the end it is 2 x 9v (or 2 x 7.2v if rechargeable).
But actually it is 1 x 18V (1 x 14.4v), because those packs are connected in series.
However, 1220B actually need 13v to operate by defaults.
I was tried even with 12v accu and it is working the same, i haven't spotted any changes in behavior.
So... it will work nicely in range 12v to 18v with no problems.
It's battery compartment is large enough to hold one 6v gel accu.
So i made voltage multiplier and tested it. Working just nice.
No problems at all.
Cscope can draw current from 17mA (with no detection, in all modes) to ~50mA (with loud sound at single tone modes) up to 150mA (at VCO audio mode when detection audio is extra loud).
So... i checked behavior with this voltage multiplier.
I get pure 16v at multiplier output without 1220B attached on it.
Than there is 15.85v when 1220B attached and switched ON.
In single tone modes at 1220B with loud audio i measure 13-14v at multiplier output.
In VCO audio mode at 1220B with extra loud audio than it is 11V at multiplier output.
Last one is not a problem, because in real life, when prospecting, it is rare case to step on such large item in soil, which will produce such loud and strong response at 1220B.
Especially when earphones are used, than power drain can not reach mentioned 150mA but barely 80-90mA.
So... problem solved.
From now on i will use only one 6v battery. Rechargeable, of course.
No problems at all.
