baterry questions
  • baterry questions
    Hello:
    Can somebody tell me which the difference is between a charger of batteries of lead acid gel and an of nickel cadmium?
    Thank you
    Carlos
    Re: baterry questions
    Hi Carlos,
    There are many theories/thoughts upon battery charging.
    For the past few years I have used a design - originally for gel-cell acid batteries - on both types. The gel-cell apparently needs a trickle-charge to bring cell-voltage up, before
    subjecting the battery to full-charging current.
    I have found that many discarded gel-cells can be "brought back". The circuit comes from "Silicon Chip" - an Australian magazine - and uses a device manufactured by Unitrode - the
    UC3906.
    This device - although expensive - measures initial cell voltage - trickle charges to a higher voltage - switches to a pre-settable heavy current charge - charges to a pre-determinded level of cell-voltage - then switches to a "float-level" of charge. That allows the battery to remain connected to the charger - with no chance of over-charging damage.
    The circuit provides switching for either 6volt or 12volt batteries, and for batteries rating from 1.2aH to 15aH.
    The article (ten pages) provides a circuit-board lay-out.
    If you, Carl, or anyone-else is interested in a copy of this article, then E-Mail me with a postal address. Sorry, I do not possess a scanner.
      Sorry!! Just realised my address was incorrect!!
      It is -
      graeme_smithson@xtra.co.nz
      g.
