md5008 meter
  • md5008 meter
    hi every one of geotech member please tell me how to do work this detector in both mod non ferrous metal/ ferrous metal what is extra technology in this detector. meter goes to left side for nonferrous metal like gold silver alluminium and other metal like iron metal goes to right side indicate meter any one has good clear schematic proper pcb layout .......rajesh
    hi rajesh,
    can you pinpoint a place on the PCB where the u-meter is connected? I mean a detector on left photo.
      md5008
      hi rajesh,
      hi kt315 actually idon't have this device md 5008 is china made. can you tell me other detector same like md5008....rajesh
        md 5008
        hi rajesh,
        hi kt 315 this detector is same like magnum but how to work meter both side left and right side for other other metal .... there aMD-5008
        Technical Specifications
        power Supply: 8pcs 1.5V Batteries in Series
        Emitting Frequency: 6.99KHz
        Signal Frequency: 437KHz
        Indicators: Visual: Lever Meter
        Indicators : Sound:2"Speaker or Earphone(Earphone not included)
        Function: Disc: Ground BalanceControls
        Function: Distinguish Ferrous and Non-Ferrous Metal
        Controls: Disc Control; Ground Balance Control
        Controls: Tune Control; Sensitivity control
        Controls: Discrimination Control
        Controls: Zeroing Control
        Operating Current: 300mA MAX at MAX Volume
        The Detecting Depth (Max): 1.5--3.5 Meters
        Sensitivity: 35cm for a US(25cent)quarter with meter
        Sensitivity : Indication at min, discrimination
          I ask about a point... I know about the detector all. no need in specs.
            md 5008
            you asked about a point but i do not keep this detector i tested at a vender shop. I know that you have detail about the detector all. so no need in a specification for you. can you submit a clear image of pcb back side layout with conect wire of meter . your posted schematic is not proper clear i wish to build this detector shortly or other similer like this..........
              i am very wondering why you do not ask me to send you fabricmade PCB or all KIT
              why you DO NOT USE SEARCH ENGINE OF THE FORUM? A? why you do not wish your eyes STAND UP AND BE WIDE AROUND? I HAD WROTE many times in many threads on md-5008.
              ENOUGH! ehough for to build the md yourself. not wait a help anywhere from anyone.
              DO IT YOURSELF! do your Home Work everysecond and people will say you THANKS BROTHER!
                md5008
                hi kt 315 i am from india so it not possible to send fabricated pcb or kit. i read your all threads interesting ......rajesh
