Originally posted by barryny
View Post
* Pick GMP or Fast program.
* Rise Sense to 94,95...even more if current conditions do allows that. Otherwise if you face a lot of silent chatters than leave it at 94 or a bit less. Be aware that Deus is very "hot" machine in those two programs. Don't be surprised if occasional short and silent chatters appears. But also don't worry about those, because usefull signal will always be very different and cognizable, also stronger in amplitude.
* Most important step: GB! Use Manual GB adjustment. First few steps give it a time to properly "read" GB and display GB number on upper part on the right side of LCD.
Walk slow and make several wide but slow swings to make it to properly read GB.
Than adjust manually GB on value which is for 2-3 higher than present GB value. For example: if it reads GB as "85" than you adjust GB to 86-87.
During your walking and searching; do observe and follow GB number as it will change repectively to changes in soil (sand).
If it change to significantly lower/higher value - than you do follow it by readjusting GB to 2-3 higher/lower than it is at the moment.
If GB change to not so significant difference (let's say from 85 up to 87 or down to 83) than leave it and continue with searching, until more significant change in GB readings appear.
Such kind of "work" is demanding and ask user to be active all the time.
Of course it is very good because that's only way to keep and maintain machine at "edges" of splendid performances.
I also have noticed one very important difference between GMP and Fast program.
Most of the time i do work in GMP. But when i face some doubtful signal where i am not sure about target character - i do switch to Fast and repeat short swings over target.
Fast turns to be a bit more accurate in such situations than GMP. But than GMP seems a bit deeper than Fast.
Those would be most important tips for fast mastering on Deus.
Of course, Deus is rich with many other adjustments. You can experiment and see.
Speaking of Deus, don't take me as ultimate expert, because i am not! I am having it only for 3 months and i do know and use only basic adjustments for now.
But even with those only; i figured out how to pull out superb performances from it.
Deus is demanding machine. Not for lazy people.
One more thing: all the time i am working at 18kHz and so far didn't checked it well at lower frequencies.
But i heard somewhere it can run very nice at 12kHz too (speaking of smaller targets).
So if you have enough time to experiment; try it and see.
Enjoy!
