blisstool ltc64x v2i
  • Daniel, I just got a Deus a week ago. I'm not concerned about which is best between Bliss and Deus. I only got into this discussion based on what I considered an improper comment of detector theory. But I have some concerns about your friends settings on the Deus.
    First I have found in my "mild" soil that G-Maxx and Relic modes are deeper than GM Power.
    I would have liked to see how it performed with Tx power at 3 and running at 8khz.
    I don't know if it would improve the results but I'm not sure the Deus was given an opportunity to perform at its best. Also the sensitivity could have been set higher but it can get chatty at those levels.
    All this said, maybe someone can explain how this thread for the Blisstool V3 become a comparison to the Deus?
    I think they are like comparing apples and oranges.
    Thank you for that great video.
    • I'm the one that wasn't that educated on programming the Deus. My buddy has had it since it came out in the US, and before that, he ran the GMP detector from XP. Our soil here in certain places, is not mild by any means. What works well in mild to benign soil, usually doesn't work well here. We did try the different frequencies though to see if it made much of a difference, and didn't really see one.
      The video wasn't done to put the Bliss against the Deus. This was actually to see how the Deus and Minelab CTX 3030 handled the hot soil. We were supposed to have another guy show up with a machine we all knew very well...to be used as a flagging detector....one that would go ahead and mark signals that we felt confident were bullets...and then to break out the new machines to see if we could set them up to achieve a signal on the targets before we dug them. It rained all the night before, and was raining when I left that morning as well. We waited out the rain showers and went hunting. Our flagger guy didn't want to come due to the rain and thus I brought the Blisstool along.
      We couldn't get the CTX to acknowledge a single bullet in our testing...despite both of us having extensive experience on the Explorer-eTrac platform. We got it to read all iron on one of the shallower bullets but most of the time nothing...running open screens in disc pattern and such.
      The Deus was then the one of interest...I was truly impressed with it, although being a specific use machine for me....i.e. the extremely loaded with iron sites, where depth is not a major concern. Just it having the bonus ability to work decent in hot soil was a major plus for it.
      • Not much happened since one week.
        Well, at least some technical related posts - that's remarkable.
        correction last post: not: As pronounced; - as announced
        No huge "Yeah!" for my new test video... - seems this is a totally waste of time and work for here. Next time I will save my time and stop shooting videos for persons who aren't interested in them.
        And perhaps I will quit my Funfinder account here anyway...
        Blisstool:
        In the last week the plastic-connector finally broke off, and any other Blisstool may get the same problem sometimes.
        Now I "soldered" it completly together - no problem just to stick the alu-pole directly into that connection-hole. If it doesn't fit tight enough solder some gum or rubber into the hole or use glue or doubleside-sticking tape. This upper plastic-screw is completly overfluous anyway.
        Second problem:
        The coil cable always touches the hand while holding which is no good. Though it's possible to fix it near the connector with some rubber band (at position below where the arm is).
        Third problem:
        Sometimes the sensitivity seems to raise and fall by itself!
        Adjusting the silencer to ten and set the threshold to 6 and the background noise in the first 3 minutes is moderate, but raises all of a sudden to "extreme noise". Now set the threshold to 2 until this chatter is gone again, but of course losing sensitivity. And this noise raising contains a huge volume level.
        Because of all this additional problems now I give the Blisstool 70 (instead 75) points out of hundred. But it is still a very sensitive and good detector which I can recommend, especially to treasure hunters that wanna search all the time in all-metal-mode!
        But it is no good for beginners and it can became a problem to persons without artisan talent if there occures some repair-works.
        But so far I know now I would give the Deus XP also just 70 points!
        I am shure they are not telling us the whole truth with the coil accu.
        They call it up to 12 hours or something - yeah, perhaps, but under badest conditions. If you wanna work at full power it may hold just 8 hours in the first year (new) and in year 3 it just works for 5 hours.
        And they are not providing a reserve accu for the coil, so you have to quit after that very short time or use a portable car-battery-charger all the time.
        And the standard coil - maybe fine for very small coins in trashy area but for shure not for huge sites where you first have to find clues etc. or for deep stuff.
        This small gold-chain comparision test someone should make who have both detectors and in both times this chain must have the same depth and shape (not in the shape of a ball or little ring but "wide").
        • coil issue
          No more replies?
          OK fine, but I have a new one:
          If you ever wanted to look inside the Blisstools coil - here you go!
          All of a sudden it got a crack - perhaps I hit a rock or something.
          Anyway - it's not fully broken, just cracked on one side with a
          little hole in the bottom that doesn't reach the coil-wires.
          The windings are located ca. 1cm above the bottom -
          a waste of sensitivity. There is some layer of blue foam gum
          to save the more expensive epoxy inbetween.
          I don't give you this information for stupid statements like:
          "Hahaha, I always knew the Blisstool is crap" etc. but to
          show an authentic and realistic picture with all facettes.
          And coils of good detectors also can get damages.
          The coils-housing plastic always is a compromise:
          If it's too brittle, it will break more easily, if it's to soft,
          the coil starts to give failure signals while even softly touching
          something (as it is at the moment the case with the Blisstool).
          The best solution is using hitec syntetic material and no cheap
          china poison plastic mixture but of course this will cost extra.
          Plastic is not plastic - there exists many differences.
          At least Blisstool should provide a fitting coil cover and construct
          this coil in a way so there is not amost 10mm of distance lost.
          I thought already to upside down this coil but it's not worth
          the effort to change the pole connector, the coil-cable etc.
          For me this crack-breaking is no problem - even hunted yesterday
          the half day in that condition. Melting with soldering iron the
          plastic together and fill the hole also with plastic and perhaps using
          some windings of duct-tape or whatever and the coil will be fixed.
          But of course it is work, it is annoying and for persons without
          technical skills it may lead to alot frustration or even to the loss of
          a functioning detector.
          So as a precaution tip better at least wrap some rounds of strong
          tear-resisting tape over that coil.
          • Where did you get that machine? What model?
            what you are showing in the pictures - does not look like the Blisstools that we see coming into the USA...the V3 version...
            it looks like you have some sort of machine parts (can't say if it's a Blisstool or not) that shows lots of wear...
            I have read that you own the basic model and have owned it since around August 2010...did you buy it new? if not how old was it when you bought it? i see you use detectors in some very rough situations..
            i will make sure that Ahmed takes care of your product if it's under the 3 year worldwide warranty - no matter who was the first person to buy it...
            thanks.
            • Thx barryny for your generous offer but it is really no problem.
              This is the 11'' coil (28cm) from 2010 (or perhaps 2009) and
              material wears out after some time of heavy use.
              You can say it was my own fault and so I also will fix it.
              I guess I have still some warranty time left but I won't need it.
              The coil wasn't used very cosy and the box was already opened
              for the additional accu-pack mod you can see here:
              http://www.geotech1.com/forums/showthread.php?t=19245
              Sometimes I may buy the 15'' coil with long cable anyway
              because I really would like to hunt with the Blisstool as
              hang around the neck detector - I know already the difference!
              If holder and coil alltogether has less than 1,5kg hunting all
              day works like a charm and is much more convenient.
              http://www.geotech1.com/forums/showp...1&postcount=14
              The Blisstool LTC64 with 11'' coil has 1.850 kg total which is still OK
              for flat sites. The 11'' coil is around 0.7kg, the 15'' has some more.
              barryny, if you have good connections to Ahmed please convince him
              that he must update the somehow stiff grey coil-cable to a much
              more flexible black one with more soft isolation. Otherwise the
              cable would break easily while "hang around the neck"-usage -
              but it is possible to substitute the original cable with 2 small RG58
              (RG58 / U) coax cables that contain steel wires for better durability
              (copper wires or those weak audio coax cables are breaking easier).
              My fazit is still that the Blisstool is a great detector for very
              small stuff, very old and already low conductivity stuff and for
              deeper slightly larger things. But especially because I can handle
              the critical adjustment signals very well. I can hunt at silencer 10
              and directly near electro-smog sources still at threshold 7 and still
              get the real signals from the erratic ones.
              The Garrett GTI 1500 would beep like a running wild keyboard
              under the same sensitivity settings! At the same location
              I can still use the double amount of sensitivity with the Blisstool
              without going nuts by too strong eratic noises.
              And I don't like detectors that discriminate stuff like mineralic
              stones. That's why I prefer the Blisstool and the Jeohunter -
              freedom for all targets - no preselection!
              Don't know if this is possible - but perhaps it is:
              Ahmed can try to add another pot where the motion-circuit
              can be regulated from full motion to full non-motion.
              And I would add a little circuit where those signals that are
              getting stronger (coming out from the white noise) get a
              significant change in audio-frequency.
              In this case chatter could be heard as "grey" while the
              weak targets (and of course good ones) start to sound like
              a melodic or at least detectable differenct tune.
              The more the audio-frequency would be spread in this case,
              the more signal noise ratio could be made audible and usable.
              I'm shure there is alot further potential for improvements
              for the Blisstool, as example an directly plug in accupack
              would be great, too. Also more lightweight coils like those
              from Detech would be a great idea, even 20'' coils would
              be imagible.
              The LTC64 v3 is not the end yet - it's just the beginning for
              even greater improvements.
              • everything fixed!
                I like plastic-surgery!
                And the soldering iron has the perfect temperature for this...
                But such things really must be done in well ventilated rooms.
                And use the right plastic material - it must mix and stick well
                together with the stuff you wanna repair, close or whatever.
                Therefore save all kind of plastic garbage in a little box -
                sometimes it could be of real good use.
                • Some new tests from AU
                  http://australianelectronicgoldprosp...-5000-tdi-1-2/
                  http://australianelectronicgoldprosp...etal-detector/
                  • Tests were done by "BlisstoolUSA.com" !
                    Don't know about Etrac, never used it.
                    But i don't see Deus's adjustments?!
                    All what i see are some custom adjustments saved at 9. place in it's memory.
                    Let me summarize this with one simple word: BS !!!
                    HUGE PILE OF BS!
                    C'mon WM6! Can't you at least trust me??
                    I don't blame the others, they don't know me, but at least you should trust me!
                    Deus with LARGER coil will EAT such coin on such depth LIKE A JOKE!
                    There is no question about it at all. I tested it dozen times so far.
                    Cheers!
                    • Coin like this one:
                      http://www.forumancientcoins.com/cat...ns.com/Coins2/
                      was "killed" by Deus and large coil at 32cm depth in VERY MINERALIZED SOIL!
                      Actually; Deus "killed" 3 of such coins, at depths 32cm, 30cm and 31cm.
                      Coins were spaced 1-1.5m from each other, in highly polluted and mineralized soil.
                      So when i see such brainless efforts to promote some homebrew on Deus's account, trying to prove homebrew is superior over Deus (and other top machines too) - i simply can't stand such imbecility!
                        So promotion video at first line.
                        But thing appear (if soil is really so heavy as claimed in first video) more stable than expected.
                        • Ivconic - what are your settings for the Deus
                          Ivconic - give me your Deus settings - i want to see what you are talking about.
                          I will use them with my large coil and let you know how it goes.
                          • Originally posted by barryny View Post
                            Ivconic explained Deus settings a couple of times in this thread. Please read back his posts here.
                            But, as first we need to know what target you intend to test, then soil condition....
                            • Here my newest very small Blisstool find - 3mm nail at 8cm (4cm wet earth and grass-roots and 4cm plants above) with 28cm coil.
                              The coil repair was a full success and I found this "nugget" at a location with even medium strong electro-smog nearby.
                              If someone here has also the Blisstool plus a few goldnuggets he may provide us some test-results (in air or if possible soil).
                              • I posted this question on Findmall/Blisstool forum today:
                                Tests:
                                There are a lot of comparative test done between Blisstool LTC64 and other known brand detectors.
                                But I cannot find comparative test between Blisstool LTC64 and Detech EDS detector nowhere.
                                Both are Bulgarian brand.
                                I am especially interested in test on small gold (about 1gram) nuggets.
                                Here is some Detech comparative test (probably promotional and with doubtful accuracy) done, but without here discussed Blisstool: http://www.deepscan.de/produkt_deepscan_eds.htm
                                I got answer imediatelly:
                                Detech EDS is way better detector than Blisstool LTC64.
                                I was not sure before, but yes, I can agree, not to say that Detech EDS look like normal detector and not like LTC Rococo Toads with those 13 controls.
