PG3B PROGRAMMER
  • PG3B PROGRAMMER
    Greetings
    I was looking on web and found pic software which supports a large number of Microchip pic's. It also has GUI. for windows and Linux (freeware).
    Software is PICPgm Perhaps someone can add Hyperlink ( computer challenged).
    It supports PG3B parallel port programmer. There are are also a few other programs that will work.
    PG3B can be found at www.olimex.com.
    I am no pic expert but will give this one a try.
    I would appreciate some feedback on the images in zip.file.
    I think everything is okay please check and let me know.
    Maurice
    HI
    Found 1 mistake no vcc on Q2 corrected and marked with X on schematic.
    Redone zip file.
    Maurice.
      Hi.
      PLEASE HOLD ON IF MAKING PCB .
      I was only able to buy 25pin socket today to check orientation on pin one.
      I had it wrong way around.
      The PDF and schematic are okay but I have to rotate socket 180 and re-route board.
      As soon as I have done this will post.
      Maurice.
        Greetings.
        I have corrected board layout , socket now right way around.
        A little smaller size= 97.15mm X 73.03mm.
        No feedback ?
        Maurice.
          Hi
          I have had more time to thoroughly check everything.
          The PDF is original source, the schematic in zip - rev A correct( my diptrace schematic)
          and the board layouts zip rev B have now been checked by me. I don't want to re post everything until requested to.
          MAURICE.
