How do you open Fisher 1280x housing? The coil cable fails around strain relief connector. I would like to short down length of this cable for about 6”.
Fisher 1280x
Open the battery compartment. At the bottom there are 4 screws, they may be gooped over with silicone. Remove the screws and the faceplate should slide out, along with all the innards. It can be fairly difficult to get it started.
- Likes 1
Thanks. I did finally see the screws, but didn't have to open it after all. The battery holder was a little wonky I guess. New batteries and the unit worked perfectly. Not really sure what I will do with this machine, as it needs a pole system, and will prolly sell without the poles.
