Max410
  • Max410
    I bought MAX410 and AD797 to replace the one euro ne5534 in the Baracuda pcb ,my question is are pin compatible? If i put the AD797 i have to change something?
    All 3 are pin compatible.
      Skws, plkease let us know if the Baracuda starts to operate better after the replacement
        Thanks, yes i'll do some experiment and then let you know i try to replace also LF412 with LT1057 you think that will work?
          I think it will work, but you will not notice any improvement because the problem is not in integrated circuits. For improvements you should change the principle (block diagram) and circuit diagram.
