All you really need is The chip, Regulator, Crystal and caps on rudimentary PCB. Plug the chip in a Uno, Program it, migrate it to a rudimentary board and your in. https://www.banggood.com/DIP28-ATmega328PPU-MCU-IC-Chip-With-Arduino-UNO-Bootloader-p-932159.html?rmmds=search
Arduino based VDI!
Hi, Good evening to all the members of this Forum. I ask for your help for a problem with arduino VDI, I can not load the sketch written by Mr. Daren (MD_V13), I tried in all possible ways, but I can not load it from many mistakes. I downloaded the bookstores reported by Mr. Daren but nothing, I can say that my arduino with liquidcrystal_I2C can load Hello World from the liquidcrystal_I2C-1.1.2 library. Please some of you who has had this problem can help me. Thank you for your kind patience.
Hi Mr. Nàndor, good evening to you and thank you for having responded, I checked what type of lcd I have is a 16x2 I2c, as I have already written I can read on Hello World, I found the right library liquidisplay_I2c-1.1.2 , And embedded menu system as Mr. Daren suggested, but I can not load the program. Below I'll make the mistakes found by Arduino:
Arduino:1.8.2 (Windows 7), Scheda:"Arduino Leonardo"
MD_V13:17: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6 _pin,D7_pin);
C:\Program Files\Arduino\examples\MD_V13\MD_V13.ino:17:80: note: candidates are:
In file included from C:\Program Files\Arduino\examples\MD_V13\MD_V13.ino:8:0:
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t)
LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows);
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: candidate expects 3 arguments, 8 provided
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
class LiquidCrystal_I2C : public Print {
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate expects 1 argument, 8 provided
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal _I2C&&)
C:\Program Files\Arduino\examples\MD_V13\MD_V13.ino: In function 'void setup()':
MD_V13:209: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
MD_V13:209: error: 'POSITIVE' was not declared in this scope
exit status 1
Thank you.
Hello dgm. It seems that the backlight command line is incorrect for your IC2 setup, I think.
"MD_V13:17: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'"
"MD_V13:209: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);"
This is my setup
int backLight = 13; // pin 13 will control the backlight
digitalWrite(backLight, HIGH);
lcd.backlight();
Try to find out why its saying this error mesage "MD_V13:209: error: 'POSITIVE' was not declared in this scope"
I hope this helps!
