Originally posted by seriall714
Arduino based VDI!
Originally posted by seriall714 View PostHello,
i was trying to Arduino & IDX PRO VDI but my IDX PRO (IDX final schmatic) doesnt see Silver ? disc pot is working i can erase all metals but in any position of disc Pot it doesnt see silver and not stable VDI also i can see difference 1 euro and beer tab on arduino but what can be wrong on my circuit or Coil ?
thanks
[ATTACH]40121[/ATTACH]
i tested also ground balace POT possibilities and NO SILVER again. tomorrow i will have another coil Maxima 1500 and we will see...
Can anyone test that IDX PRO arduino VDI can show VDI number in how many CM ? i need data for 1 euro for exampe 30cm detect distance and 20cm VDI result distance...
thanks
Originally posted by seriall714 View Posti tested also ground balace POT possibilities and NO SILVER again. tomorrow i will have another coil Maxima 1500 and we will see...
thanks
i give nothing on air test
ist just for first function test and no more
50cm for one 1€, yes no Problem, give more power on tx and you will receive your 50cm
but in real ground you get more falsing
if you pickup a 1€ coin at 20cm in real ground while discriminating a screwdriver or a big nail the detector works good, if you get 30cm it is top
I used the machine for a couple of years. Large copper coins 10" in the ground is pushing its limit. Small silver under 7" I didn't use enough discrimination to fully knock out iron but listen to the break up of the sound through quality headphones. Otherwise sensitivity tiny silver on its edge is nearly halved
Made several coils. Having a coil that runs quite in the field is for more important than out and out depth. Otherwise you will miss all those faint signals.
hello, seems i am a bit late to this party. very interested in this project. but it seem the links and stuff are not working any more
i have a whites coinmaster 6000 that i would like to experiment with using arduino and well into the electronics metal detector hobby builds
these videos show exactly what i would like to learn more about, but there is not much info on how to get started. thanks
https://www.youtube.com/user/dobybowers/videos
since ADC will now work with about 2/3 of its possible range (0-3.5V, vs 0-5V); VDI will not be as good; that being said I think it will work since the min/max values of the ADC are setup parameters. You may have to lift the coil up from the ground to prevent more signal into range below 3.5V. You not risking anything; chips are pin compatible; just swap in 602 if/when you get it.
Originally posted by Daren View Postsince ADC will now work with about 2/3 of its possible range (0-3.5V, vs 0-5V); VDI will not be as good; that being said I think it will work since the min/max values of the ADC are setup parameters. You may have to lift the coil up from the ground to prevent more signal into range below 3.5V. You not risking anything; chips are pin compatible; just swap in 602 if/when you get it.
Thank you
