Help with brutalised detector "enigma"
  • Help with brutalised detector "enigma"
    Hello, I have(had) an old but nice detector, after i gave it to friend it came back like this.
    I don`t know where to connect the power suply, the coil(s), etc...
    In two words I want to put it back together. Will appriciate any help.
    The IC in red is with broken leg
    linking photos:
    This will be hard to set right without another unit to compare or a diagram. You are very generous to still call this person a "friend."
    -Ed
      looking for on PCB the biggest electrolyte capacitor + and -.
        This looks a lot like an older Fisher.
          It's a predecessor of the Blisstool detector.
          Rumour has it that the Enigma is a modified version of a 1236.
            As far as i know, it should be version of magnum.... but... I didn't found much in common ...
            Thank you for digging this!
              Carl,
              there is not so specific Fisher transformer in TX stage. so it is not due a fisher clone. at PCB stay three 4046's and I have to say the detector was done by '4046s' lover'. may be done by this Bulgarian man who had emigrated in UK, the author of NEXUS. this is my opinion, may be subjective.
              good luck
                Carl,
                this is popular in Poland ALL-1 schematic based on old Fisher design. model 553 or 555 - I do not know what they took. no 4046.
                  some Progress
                  Found where to connect the coils, battery, disc knob....
                  todhay will start the restauration and post results.
                  Thank you again for digging into this
                    hi all first post ive repaired lots of eastern block radios in my time
                    and if it helps you out those electronics are very soviet in style
                    it may be an e block clone but if it is its not the end of the world
                    while it can look a mess to western eyes it works just as well when set up properly but if it turns out to be eblock tech be wary of capacitors(crap) best to replace
                    russian sites can help with codes rating and such(if non standard sometimes is)
                    good luck aly
