really i want to know...
  • really i want to know...
    hi guys
    for baracuda metal detector, can it used on lands?,because i wanna make metal detector for land with normal depth (20-30cm in soil) is baracuda optimal for my request? or there's other one better?,which metal detector u recommend to i choice to start my pro?,sry because i had asked this question before but i forgot to told u that i will use it on lands not on beaches because i live in Jordan and all my searching going to be on lands with small objects at depth between 20-30cm in soil,and i can't bought a one because it's forbidden in my country and no one sell it, they say if u wanna one make it ur self, the solution is that i should build it my self,if u give me the answer last thing is what's the optimal search coil for that metal detector u will recommend it, like its kind,diameter,number of turns, diameter of the wire..etc.
    thank a lot
    Originally posted by $hooter View Post
    hi guys
    thank a lot
    The Baracuda will work inland ... but ... it will detect all metal. So it depends what you are searching for and where you are searching. The bottom line is that you will have to dig everything, and cannot ignore iron. Is this what you want?
      Hi
      thank for note, i don't want metal detector don't have discrimination and cannot ignore iron, i wanna one have some discriminate and can ignore iron and with depth(25-30cm it's appropriate,or more) for not big object, because i will search on lands that have an artefacts, in my country have so many archaeological places,the bottom line is that i wanna metal detector for lands(where there is no moisture), so what u say? about the choice.
