help with surf pi, trying to make it work!!
  • #61
    Originally posted by pavlos_x View Post
    some help please? this thing is totally unstable
    Power ok now, the currents are normal .. , have you updated the NE5534 ?
    Can you find now a zero DC at NE5534/6 when adjusting the offset pot ?
    If so then turn the delay potentiometer and see if you can detect gold..
    • #62
      NE5534/6 is adjusted to zero and with offset to midle(changed the pot with a diferrent one)
      http://i.tfcdn.com/img2/J98tLk4AY5r8...OAA**/fyVMtP8A
      ''have you updated the NE5534?'' we had problem with 2n3906 and i putted a bc307a, but i had it otherway around now i fixed it's fine. i detect iron at 10cm and gold at 2cm i changed 4 coils and still the same results.
      • #63
        coils that i tried are
        wire(with pvc shield) 0.5mm 17turns 20cm diameter ----> big iron at 7cm
        wire(with pvc shield) 0.5mm 22turns 20cm diameter ----> big iron at 10cm
        wire(with pvc shield) 0.5mm 17turns 27cm diameter ----> big iron at 10cm
        wire(naked copper) 1mm 17turns 20cm diameter ----> nothing just buzzing
        • #64
          something is keep buzzing all the time but it detects, my distance of detect is too small, is something wrong apberg??
          i even made another coil
          wire(with pvc shield) 0.5mm 24turns 20cm diameter ----> big iron at 10cm
          • #65
            are you adjusting offset for each coil ?
            buzzing sounds like bad coil
            adjusting delay may take many turns, the pots I supply are 25 turn pots
            It sounds like you are almost there, maybe just a resistor in wrong place?
            can you post some more pictures, close up of each part of the board so we can see the resistors colors ?
            • #66
              Any time you have power supply reversal it can cause incidental damage to components. Your having +4V where you should have had -4.5V was such a reversal.
              You should replace the '4066 then think about replacing the opamps if you still have problem. Make sure you do not use 74HC4066.
              edit: Thanks for the schematic and link, ApBerg.
              • #67
                YES am adjusting it to zero each time, i changed delay pot to this
                because i broke it :P
                its too dark to take a good foto and with flash you cannot really see well
                i just test all resistors with multimeter
                all resistors are ok from your side part list except these:
                R11 is 12.8k instead of 22k
                R22 is 88k instead of 100k
                R20 is 5k instead of 22k
                • #68
                  • #69
                    Is R25 soldered?
                    • #70
                      I suggest you replace C1 and R2, which have been damaged by the soldering iron.
                      • #71
                        Nooo, man. Those dings just add character to the final product!
                        • #72
                          being sarcastic doesn't make you smarter! i was planing to change them, i had no choice, i had to make the soldering on top of pcb where the problem was and then check it with components on to see if its ok, R25 is ok
                          • #73
                            I guess I can never be as smart as you are, or have such a good sense of humor. Oh, well.
                            • #74
                              chill out my friend just messing with you
