Need Guru to look at 5534 scope shot,something is wrong.
    Originally posted by Brian Deese View Post
    No I have not,can I test them in circuit?
    I guess you can. If not; than at least lift one side from pcb.
    If i understand circuit correctly; those are there for overvoltage protection.
    BUY92 is cool, warm or hot?
    Have you checked it?
      Type Designator: BUY92
      Material of transistor: Si
      Polarity: pnp
      Maximum collector power dissipation (Pc): 30W
      Maximum collector-base voltage (Ucb): 150V
      Maximum collector-emitter voltage (Uce): 60V
      Maximum emitter-base voltage (Ueb): 7V
      Maximum collector current (Ic max): 7.5A
      Maximum junction temperature (Tj): 175°C
      Transition frequency (ft): 60MHz
      Collector capacitance (Cc), Pf: -
      Forward current transfer ratio (hFE), min/max: 40/80
        1N5341 (6V2) + reverse 11DQ03 (app.0.55V) = approx.6.75V
          It looks as a perfect AC coupled response to me.
          Check your probe, and ensure you have a DC reading on your scope. With DC reading your yellow traces should get straighten up and you'll lose a zero crossing thing.
            Nothing ever gets warm on this board,It is a really low power machine.Those buy92's are tiny metal can,about a pencil eraser and they have heat sinks about 1/2" diameter on them. I dont think there is anything wrong with the tx,the waveform from the coil looks just like I expect it to.What do you see,that I dont? I am still a novice at electronics.
              Both of the scope probes are DC coupled,if thats what you mean.I only use AC coupling if I want to see ripple on the trace.
                I see nothing more than you do. But Carl's suggestion made me think that something is not "in range" there:
                Carl:
                "...Most likely the coil is very slightly underdamped, not enough to see it on the scope but enough to make the preamp flip. Slightly reduce the damping R by adding a resistor in parallel (perhaps 10k) and see if it goes away..."
                  OK, but how do you obtain the yellow trace? There is obviously some voltage divider in action. What kind of voltage divider is there?
                  Whatever you have, you'll find some kind of AC coupling.
                  I already like that rig. It is mostly the way I'd make a bipolar pulsed PI myself - knowing what I learned so far. With inverting opamp in a frontend and proper transistors for drives.
                    The yellow trace is the input to the 5534,I have the scope probe hooked on one of the overvoltage protection diodes.You mean because the yellow trace is small in amplitude? The overvoltage diodes limit the peaks to .7 volts, thats standard issue frontend correct? The red trace is the output and there is a test pin to hook the scope tp8. I was going to offer you the schematic when I saw some of your posts' but It seems you have your design figured out.I cansend the full size schematic to you,or its posted in the schematics section also.
                      Carl:
                      I have to pull those damping resistors back out,I know it. And if you look at the above picture the yellow trace alone you can see a tiny peak cross zero.But the red trace doesnt seem to follow it in time is my complaint. I am having trouble swallowing it because the coils only measure 185uH and the tx pulse is only 50uS,its a low power machine,and it already has 330r damping resistors.I just dont see how its ringing. But something is not right obviously.
                        That's why i suspected diodes and base "biasing" voltage. It is "fast" PI machine yet with bipolar transistor and not with fet. It is much more difficult to control bipolar transistor in such conditions, so any possible variations at base voltage would cause also something like "ringing" and indirectly will affect rx too.
                        I had similar issues long time ago with such "bipolar" design.
                        You actually don't need to resolder diodes to examine them; just measure voltage across them. (that's why i gave you reference 6.75V to start with)
                          Ah, so you actually measure the opamp feedback compensated input, and not the voltage on the coil. OK, that makes sense. Trouble with such measurement is that you actually look at the place where a voltage should be different from zero only in times the opamp is saturated, and such measurements will lead you nowhere. This is very different from non-inverting opamp stages where input follows the applied voltage. The inverting one fights back and tries hard to keep its input at zero. What you observe is just the way the opamp recovers after saturation, and it is perfectly OK the way you see it.
                            IMHO sexy MOSFETs just make it worse. BJTs may need some more juice to drive, but they do not introduce much capacity to the deal, like MOSFETs do.
                            A reality check: business part of the PI signal is a beginning of the off time, and that calls for high R. MOSFETS bring low R to the table ... not very useful, and it comes with high C attached to it.
                            Lower R -> higher C.
                            Low R unimportant, high C problematic -> to hell with low R MOSFETs.
                              "...BJTs may need some more juice to drive..."
                              That's the spirit!
                                What i ment: no wonder White's did it that way.
                                They do know how to "milk" the juice...
