Xactor Xtra Hands
  • Xactor Xtra Hands
    Looking for a cheaper solution to these.
    http://www.ebay.com/sch/i.html?_saca...magnify&_frs=1
    Or something better if anyone knows. Thanks!
    I have one of those. I mounted a larger glass on a goose neck holder for a microphone so it is flexible and use the alligator clips for holding the circuit board.
    However seeing close detail even with the glass is a pain. So what I have done is recycle an old dark room enlarger and mounted a telephoto lens from a 1960's vintage television camera on it.
    I use this as the lens for a closed circuit TV camera. I can take a small PC board and display it full screen on whatever sized TV monitor I have and put that right behind my work so I see the PC board and the TV monitor in the same sight path.
    The present camera I have is black and white so am looking for a color camera that I can remove the lens from. I think I have found one that will work.
    As this point I have not tried using it for PCB soldering so the whole idea may be just a crazy scheme by someone who is visually challenged
    Jerry
      Good Idea. Im not sure what I'll use it for. Thats why I want it cheap lol.
