possible coil nulling method?
  • possible coil nulling method?
    hello
    after reading the first chapters of the new book inside the metal detector
    i got an idea
    i have a tens unit for therapeutical use
    with this unit i can send electrical pulse to electrodes
    for example max specs
    100Hz
    80mA
    pulsewith up 450micro sec
    it is power by a 9volt battery
    if i connect this unit to a tx coil i should be possible to get a measureable signal at a rx coil
    an if i connect a mutlimeter in mV range to rx ciol it should be possible to null the coil arrangement
    or not
    a next step is to use the pc and the programm nch toner pc linked to amp or tens circiut
    so i could send for example a 14khz signal the strengh is regulated over the linked amp (one channel of a pc speaker)
    what do you think?
    You do not need real Tx detector stage as frequency source to nulling coil.
    Any other equal frequency source can do the yob in the same way.
    The same on Rx site, sensitive enough mV-meter do the job very well.
