Building a vacuum table.
    That was very instructive Don. I have been waiting until the heat is such that there is a much larger sag in the plastic in the frame before taking it out of the oven. My results are as you describe in your last sentence.
    I had a question about joining the corners of the frame but edited it out when I looked back and saw that they were cut from a single sheet of plywood. Any special type of material? Whenever I try cutting something that thin with ordinary plywood, I frequently will get chips out of the top layer in places.
    Looks like it is time to dig out the saber saw. Your frames are much thinner that what I have been using. It is snowing and everything is shut down for the day so this looks like a good project.
    I enjoyed the video, thanks for doing it.
    Jerry
      Hey Jerry. I know what you mean about cutting plywood. Try going with plywood with one finished side and cut it with a fine tooth saw. Or.. you can cover the surface of the wood with masking tape. That helps minimize splintering too.
      Don..
        Don, inspirational as ever. Never seen it done before - moving pictures are worth a million words. Legend
        Steve
          Don,
          How do they ship those 48"X 96" sheets referenced in your link? Will they cut them to smaller size or just roll it up into a tube? I like the price compared to what I have been paying for smaller sized sheets from Micro-Mark.
          Jerry
            Yeah, prices are unbelievable... the only distributor I found in The Netherlands for ABS sheets is farnell. They charge 4 times the price.
            Anyone know a firm in Europe who sells 1.5mm ABS sheets for a good price?
              Originally posted by Jerry View Post
              Don,
              Jerry
              They roll it up in a tube - about 48" x 12". I was originally buying 6 sheets - 16" X 16" from Micro Mark as well, and thats' OK of you don't want to make more than 6 coils. U.S. Plastics sells the same thing for 1/3 the cost, but shipping is still a killer. I can get 18 sheets from U.S. Plastics for the same cost.
                Thanks for posting all of this good information. You certainly set a high standard for all of us to follow.
                Jerry
                  Here are a few tricks that I have learned and hopefully this will help keep builders from unnecessarily wasting material.
                  1. Drill an air hole in the center of your pattern - It will help the vacuum to draw air out of some of those tough places!
                  2. Place your pattern on a group of coins. It helps the system remove air quickly.
                  3. Removing your pattern - Do not try to pry the pattern out of plasitic. Just tap the edges of the plastic on a table top and the pattern will work itself free and drop out.
                  4. Build a simple jig for aligning a pilot hole for drilling the ears on your completed coil. Nothing is more annoying than a crooked hole.. and that is what I get without a jig .
                  The jig is just a block of wood with cuts made on a table top saw against a rip fence. Note: It is virtually impossible to drill a long, straight hole through the block of wood. It
                  is far better to cut a groove to assist in drilling a long hole. Then fill the cut with epoxy or glue in thin strips of plywood.
                  Hopefully someone can learn from my mistakes!!
                  Don..
                    Don..
                    Top posting right there.
                    S
                      Don, again great info !
                        Don..
                        Another trick I use is to varnish the pattern several times, giving a light sanding in between coats so the final finish is very smooth. I apply liberal coat of wax just before vacuum forming. It pretty much falls out of the shell.
                        I like the tip on the penny spacers will try that next time.
                        Jerry
                          I have been looking at buying a coil cover and using it upside down.
                          So the coil sits in it and use that as shell. Pot it from above, coat inside with graphite/carbon paint as usual.
                          Cheaper than buying the pc abs.
                          http://www.staffsmetaldetectors.co.u...oil_covers.htm
                          Any thoughts?
                          S
                            Any thoughts?
                            S
                            In ITMD, Chapter 10, we describe a simple method of constructing a coil using a commercial coil shell and either 5mm 3-ply, or MDF, for the top of the shell. This method allows the ears to be easily constructed out of offcuts from the 3-ply. However, you might have to be somewhat creative if you wanted to fill it with epoxy.
                              And now, for your viewing pleasure and entertainment.. What happens when vacuum forming goes really really bad.
                                No...no...is not bad....its a piece of art... you can put it on the wall ! , just give it nice blue eyes an a smilie red mouth ..
