PLA stands up fine in water, it only breaks down when subjected to body fluids according to what I have read, however one note on this is I noticed one of my PLA rolls has become quite brittle, I suspect that its because I do not have a range hood or extraction fan in my kitchen and its been subjected to a fine layer of animal fat like everything in my living area.
I have been printing in ABS lately and its not necessary to print in a box, well at least not during an Australian Summer, Winter might tell me a different story.
My last coil I printed in ABS and is virtually unbreakable, its very strong flexible material, its epoxy reinforced to which makes it more rigid and water proof.
My printer is down at the moment with a blocked nozzle, when removing the nozzle I found the nozzle temperature sensor wires were hard wired to the nozzle somehow and I broke these wires, still scratching my head about this and how to fix it again, might have to throw it in the bin because if there is a sensor in the nozzle I don't think there is any way I will remove the sensor to re-solder the wires, really it should have had plugs fitted to it but I guess you get what you pay for, to complicate things further the design of my Prusa nozzle is nothing like any other Prusa nozzle I have seen so ordering spare parts might not be that easy either, I may have to manufacture my own nozzle but this is also not desirable as putting a 0.5mm hole through stainless steel is not so easy especially on my antique hobby lathe.
