Well I had a interesting Lithium Battery experience today, I guess that says what a nerd I am, any way I bought a laptop battery pack from the local thrift store and cut out the cells from it. What was odd, they were all flat dead, 0 volts. normally one or two will show 3 or 4 hundred mV and some times I can bring them back from the grave. But 0 volts? they acted like they were not even in the charger. so I had to do my favorite thing, I took one apart. What was Interesting, under the cap of the pos-electrode was a dome that had been connected to a fine mesh that was then connected to the electrode. from what I gathered from the arrangement, the metal dome would go up and down from gas discharge while being charged. that in turn would cause the mesh to flex and after a certain number of charges the mesh would give way due to metal fatigue. I other words after, say a thousand charges all the cells die at the exact same time. corporate planing at its finest, a real picture of the future to come. Well I thought, if I push the mesh under the the electrode until it makes contact with the dome? CONTACT it works. I had to take a very small probe that will fit in the holes in the electrode and then while the battery is connected to the charger I gently pushed on what I thought was the center, you have to do it in the blind. When the charger shows that it is charging your done.
Zoom in on the pic to see better.
Li-Ion Battery experience
Interesting detective work. I've come across this 'open circuit' Li cell phenomenon myself, and always thought that it couldn't be a chemical effect, it had to be a genuine open-circuit. I wondered if they had a thermal fuse (the non-resetting low-melt solder blob type) in them, or a pressure activated breakable wire. But I never really fancied dismantling one - despite taking apart plenty of other cells, including mercury ones.
What were your cells, cylindrical types like 18650 etc?
Do you think your solution will be durable long-term?
Any side effects, like higher internal resistance?
it Sound like you activet the short circuit or overload protection of thes cells
they should prevent a bigger damage
i often use 18650 or 14500 cells for my Projects, i am very happy with them
better that These nimh packs and lipo cells i used before
so i plan every new Project which Needs battery power to works with 18650 or 14500
