PCB headers for coils and power pack.
  • PCB headers for coils and power pack.
    The MiniPulse Plus that I'm building comes with sets of headers with 3 pins in a manageable size. I wanted to buy more and when searcing in Google, aliexpress etc I only see "micro" headers made for 20 y. olds with steady hands and sharp sight.
    Who can point me to a manageble set of headers the kind used in MiniPulse Plus?
    Thanks to all.
    Hi Teleno
    Something like this cut in half works well.
    Have a good day,
    Chet
    http://www.ebay.com/itm/5Pcs-3P-3-Wi...8AAOSwpzdWsWNR
      I use radio control servo leads for models.
      http://www.ebay.com.au/itm/10-x-3Pin...0AAOSwyQtVh~xf
        These are much better priced
          What about the PCB side of the connectors?
            They are called header pins just snap off and solder
            http://www.ebay.com.au/itm/10pcs-40-...IAAOSwewJTmm9w
              I would not use none locking connectors again. Accidentally dropping you detector and then having to take it apart in the field is over rated. Last detector I built I soldered all leads directly to the board. Just one less thing to go wrong or corrode.
                Or you can apply a small drop of hot glue to stop it coming loose. Having removable connectors is very useful during the building, testing and debugging phase.
                  I use connectors all the time now.
                  Headers and servo connectors are fairly tight.
                  There are crap ones and good ones.
                  http://www.hansenhobbies.com/products/connectors/
                    Just splay the outside pins like a Y , works in R/C planes.
                      Next time I take my IDX apart I will do that
                        It only takes a fraction to splay the pins, and then use needle nose pliers to squeeze the pins parallel then slip on plug, its easy to do.
                          here you go.
                          http://futurlec.com/ConnPolHead.shtml
                            Originally posted by nickel_n View Post
                            These are the headers in the MPP kit. Exactly what I was looking for. Thank you!
                              I have added these connectros to the shop
                              http://www.silverdog.co.uk/shop2/ind...ory&path=25_45
