3D treats
  • 3D treats
    Ok, those who are having good will to share are welcome here to give their treats:
    250mm DD
    DD_250.stl.zip
      Elips DD
      ellipse_DD.zip
        20 cm concentric.zip
        Pinpointer.zip
          scale Spule stl to height you want, no infill but with at least two wall lines, or one very solid wall line, and several bottom layer, adjust flow of first layer to 120%
          rest is at yours
          you can also print one massive form to use it as positive form for vacuum forming
            Stick_28mm.zip
              I picked up this from the internet.
              I made small modification and added elements for better elastic band attachment.
                Bolt & nut
                Thanks for shared to all for above uploaded..These are so beautiful,,,
                I'm looking for 3D .stl file bolt & nut like this one, does anybody has it?Click image for larger version
                  I'm looking for 3D .stl file bolt & nut like this one, does anybody has it?[ATTACH]54214[/ATTACH]
                  That looks like a toilet seat bolt, check the hardware store.
                    Genius! Thanks Guru
                      are you the guy from russian forum who produce detectors based and eddies pitone project?
                      can you share you enclosure files and grip, armrest pieces?
                        No, but you can see Sergey design and download all the files here and here
                          And here and here
                          I even tryClick image for larger version
                            Many thanks
                              Thank you so much
