The width of the lower rod where the coil attaches varies by model and brand of detector. So how do you make a single coil shell mold that fits multiple lower rod widths? Here's my solution...
These wings are machined/polished 1/4 inch 6061 aluminum with six holes drilled and tapped (6/32) in the bottom. To vary the width of the wings to fit different sized lower rods, a staggered pattern is drilled into the coil shell mold as shown in the 3rd pic below. This particular pattern fits lower rods of .900, .750, and .720 inches wide. Note that regardless of which pattern is selected either none or very little of the other holes are exposed, certainly not enough to effect vacuum forming with .060 ABS.
I decided the wings had to be drilled "after" they were machined because the screw hole location is critical. If I predrilled all the holes and was off even a little when I flipped the stock flat to machine the wings, the error would be cumulative. Therefore I had to machine a jig to hold each wing in the vise for drilling as a final step. I'll post a pic of the jig if anyone is interested. Mostly I just thought I would get this new forum started with a post! :-)
