Gauss Meter
  • Gauss Meter
    Hi Guy’s,
    I have constructed my own shape of coil using the inner workings of a Coiltek 14” round mono. It works well except for one sensitive area (hot spot). It is time to carry this project to the next level and need a little help. I have gathered all the materials needed to build several coils for testing. I would like to be able to test the coil bundle shapes as I go. I have an oscilloscope at my disposal and have purchased an LCR meter (thanks to SimonBaker) now would like to buy a not too inexpensive Gauss meter. I tried looking on e-bay and have no idea what to buy. What I need to know before purchasing is the range the meter I buy should have? i.e.
    Milligauss .001/.999
    10’s 10/99
    100’s 0/999
    1,000’s 1000/9,999
    Any help would be appreciated. KinnyP
    I don't know if this is of any help to you, but check out page 69 in the attached PDF file. It's a magnetic-field probe with minimum components. I build it just out of curiosity and it was OK for relative measurements on several coils with a 10kHz signal. I don't think you should trust the absolute measurements unless you buy a calibrated sensor, but for finding spots in your devices it might be all you need.
      Hi gwzd,
      I appreciate your help to my question. I think at this point in time I best stick with a store bought tester. I probably have a dozen coils at my disposal for testing. I am not interested in absolute measurements, only the approximate differences from coil to coil. The coil I made works really well for a first attempt and I’m hopping to improve on it. Reading between the lines I see your recommendation works well with 10 kHz signals. Would you say that is about the middle range for coils used on a PI detector? Thanks again, all help is appreciated. Kinny
