Can any one tell me what kind of adhesive to use on Lexan. I am planning to put a Tesoro Compadre in a water proof box made of Lexan... thanx
Lexan adhesive
Lexan is available in two types:-
Lexan Plexiglass Acrylic and Lexan Polycarbonate
If you are using Plexiglass then the suggestions given in previous posts should be fine.
I have also used plexiglass shavings dissolved in acetone as a cement but
it is not very good , but it does fill gaps.
Lexan Polycarbonate can be glued with a solvent called isophorone ( 3,5,5-trimethylcyclohex 2 enone ) .This solvent is usually found in cements for uPVC Pressure Pipes for mains pressure water. See example at
http://www.wolseley.co.uk product code F09922
A workshop manual on Plexiglass / Perspex ( in the U.K ) including suitable cements can be found at :-
http://www.gcip.co.uk/pdf/perspexmanual.pdf
Hope this is helpfull
Ron_o
