Eagle 5.60
  • Eagle 5.60
    Hi.
    I use (not often) the Eagle 5.60 and i have a problem with names and values of components. I don't know how to manage them, so a lot of them are above in other values or names, so i can't read what it writes. I want to find the solution so to complet the schematic of Mineoro and to post it at remote sensing.
    Hi.
    Geo, hit the 'smash comand' in the panel at left. By doing this, you unattach the values from the components and then use the move comand to place them where you want it.
      Hi Hung.
      I tried it and i saw that works OK.
      Thank you
        One layer
        Hi again.
        How i can draw a one layer board????
        I can't make a pcb with less than 2 layers.
        Any idea???
          I found the solution.
          Anyway thanks......
