What to clean pots with?
  • What to clean pots with?
    What is good to clean pots on an older detector with? I have one and some of the pots are a little scratchy.
    Plane O'l Tuner Cleaner.
      Watch out with ordinary contact spray. This stuff is normally used for switches and it is very aggressive. If you can get to the resistors, I would try alcohol. Apply with a cotton tip and turn the pots a couple of times with the detector turned off. Then let dry.
      If cleaning doesn't help, your pots may be worn and you have to replace them.
        Get a SPECIALIST can of switch cleaner (WITH LUBRICANT) hold the pot with the hole facing DOWN and spray liberally, allow to dry and repeat a couple of times moving the wiper GENTLY each time.
        If you use Alcohol you will dry out the shaft AND track lube, this will make the pot wear out a LOT faster.
        NEVER, NEVER use WD40 or the like, they leave a film which dust and grot sticks to making the pot even worse that it was before in a very short period of time.
        I learned this when I serviced detectors, I ALWAYS cleaned the pots whether the user asked for it or not, and the crap that came out of most was unbelievable!
        http://uk.rs-online.com/web/p/precis...luids/2987729/
          you can go in your near electronics shop and ask. they will tell you due the aerosol they has.
            Thanks but rhe pots arw beyond cleaning and ebay doesnt have anything close.
              What pots do you need: value-log/lin-lenth/dia of shaft pot size overall, pictures speak a thousand words.
                Pics in tech section
