BOOK - How to build your own metal and treasure locators by F.G.Rayer
  • BOOK - How to build your own metal and treasure locators by F.G.Rayer
    Another book from the seventies, a first print from 1976, this time from the UK. Cover here ---> Click image for larger version
    No surpise, all detectors in this book are simple BFO types which operate at about 300-500 kHz. Here's the contents table:
    Introduction..................................7
    PART I PRINCIPLES AND CONSTRUCTION
    Non-Interference..............................8
    Stability....................................9
    Regulatory Department, SensibIe Use..................9
    Production of Hetrodyne.........................I0
    Hetrodyne Locator.............................I2
    MetaI Finding................................l3
    PracticaI Circuits and Construction....................15
    Soldering...................................16
    Transistor Leads..............................17
    Reference OsciIIator............................I7
    Testing and Fault tracing.........................22
    Search Coil Oscillator............................27
    Coil...................30
    Testing.......................31
    Handle....................................32
    Hetrodyne Detector............................33
    Audio AmpIifier...........................34
    Completed Locator............................37
    Pitch ControI................................38
    Locato rUse................................39
    PART II ALTERNATIVE COILS, DETECTORS, AMPLIFIERS
    Frequency Stability.........................43
    Broadcast and Wound Coils........................45
    Air-Cored CoiIs..............................47
    SEARCH COIL ASSEMBLIES
    Shielded Coil................................53
    Two-Terminal Coil............................55
    Square Coil.................................57
    Basket Coil..................................59
    Underwater Coil..............................60
    ALTERNATIVE DETECTORS
    Transistor Detector.............................62
    Detector Faults..............................65
    AUDIOAMPLIFIERS
    Headphone AmpIifier..........................66
    Two-Stage Amplifier............................69
    Three-Stage Amplifier...........................71
    lC AmpIifier.................................73
    PART III CONSTRUCTIONAL AND OTHER POINTS
    Search Coils and Handle......................... 77
    Case........................78
    Very High-C Loop..........................78
    450—470 kHz Working..........................80
    Oscillator Stabilisation..........................82
    Kind of Metal..............................83
    3-TRANSISTOR LOCATOR
    Search Coil...................................83
    Coil L2 Circuit and Tag-board......................86
    Alternative Coil...............................87
    Case..............................88
    Originally posted by joop View Post
    Another book from the seventies, a first print from 1976, this time from the UK. Cover here ---> [ATTACH]30850[/ATTACH]
    Yes, I have that one as well!
    If you're into collecting metal detector books, then here's a few to consider:
    1. The Complete VLF-TR Metal Detector Handbook (All about ground cancelling metal detectors) by Roy Lagal and Charles Garrett
    2. Building Metal Locators - A Treasure Hunter's Project Book by Charles D. Rakes
    3. How to Build Proximity Detectors & Metal Detectors by John Potter Shields
    4. The Electronic Metal Detector Handbook by E. S. LeGaye
    5. Ortungstechnik fur profis by Wolfgang Schuler (in German)
    6. The Advanced Handbook of Modern Metal Detectors by Charles L. Garrett
    7. Seeing Beneath the Soil (prospecting methods in archaeology) by Anthony Clark
    8. Signal From the Subatomic World (How to Build a Proton Precession Magnetometer) by Stefan Hollos and Richard Hollos
    9. Teoria e Tecnica Avanzata del Metal Detecting by Leonardo Ciocca (in Italian)
    10. The Magnetic Measurements Handbook by J. M. Janicke
    11. Das Kompendium Der Metall Detektoren (Theorie - Planung - Praxis) by Rolf Wilhelm - Elektor Verlag
    I've heard there are some good Russian books as well, but I don't have any of those.
      Great list! I have 1, 5 and 6 also and own one which is not on your list: Schatsuche mit Metalldetectoren by A. Gatowski. Will write a short review about this book later this week!
