barracuda 60 cm coil
  • barracuda 60 cm coil
    i wonder if there is someone who made a bigger coil for barracuda???? because i made several 60 cm coil for my barracuda this week.. the result is poor.. 1st coil is 400uh, 2nd is 540uh, and 3rd is 490uh..all coil is poor in detection.. maybe barracuda will not properly run above 40cm coil because of the pi ability.
    what targets you guess to hunt on with the 60 cm coil?
      Old war relics and other big buried object..but with that 60cm coil i could only detect a 40x60cm metal plate at 100cm.
        this device works with low pulse width, good enough for small stuff. it doesnt matter if your coil is big it wont be deep for war relics and other deep large objects. try delta pulse/xr71 for that.
          try delta pulse/xr71 for that.[/QUOTE]
          Yes delta can go deeper..i have one but problem is delta is very temperament.
            barracuda is submersible detector thus an amount of pots on housing is so minimal. only two - threshold and delay.
            MINIMALIZED FOR ESPECIAL APPLICATION UNDER WATER.
            try increase PULSE WIDTH, but you get more quick discharge of battery. you get only head crack trouble if hoping
            something to change. if you want to get the deeper - do the deeper, if want to get waterproof - do the waterproof.
            no other rule. you can not make Ferrari from Folkswagen Golf.
              Delta
              Please tell me what do you mean Delta is temprament? I'm planning to build next month thanks to master KT315 4sharing it
