IB Metal Detector Project, Part 3
  • IB Metal Detector Project, Part 3
    I am counting (or guessing) instruction cycles to get an estimate of the processing load and to figure out what processing device I can use.
    It looks like the interrupt overhead just to save and restore essential data is about 20 cycles per interrupt. 20 * 26,400 is 528,000 cycles per sec, which is more than half the throughput of the 4 MHz chips. I don't have to do any more math than this to see that the 4 MHz parts are not fast enough for a 26400 Hz interrupt rate in this project. So I will assume I am using a 20 MHz chip.
    By counting and guessing I get:
    20 cycles overhead
    20 cycles maintaining counters and figuring out what to do on this interrupt
    10 cycles controlling the transmit signal
    subtotal: 50 cycles every interrupt
    In addition there is extra work every 3rd interrupt:
    10 cycles read A/D and start next conversion
    55 cycles median filter
    10 cycles accumulate result
    subtotal: 75 cycles every 3rd interrupt
    Total for interrupts: 50 * 26,400 + 75 * 8,800 = 1,980,000 or 40% of the throughput of the 20 MHz chip. Assume I forgot something and round this up to 50% of the chip's capacity for the fast loops. That leaves the other 50% for the 60 Hz loop. That is 2,500,000 / 60 = 41,666 cycles available per 60 Hz loop. I have not started adding up cycles in the slow loop but 41k is a number I feel comfortable working with.
    I can also see that if I can really get all the work done in the long (3rd) interrupt and have time to set up a few flags I can skip the 20 cycles of overhead on the short interrupts because I can test bits and set bits without altering W or the status flags, So as long as I can get things set up ahead of time my short interrupts can be shorter than I estimated above. That gives me a little safety margin.
    But in figuring this out I ran into a couple of problems. While looking at the number of bits required I decided that I wanted to use a 12 bit A/D not 10. Then when I went to look up the part number, I could not find any chip with flash memory and a 12 bit A/D.
    I also noticed when looking at the A/D timing that it has a 5 micro sec amplifier settling time. Since I am sampling a 6600 Hz sine wave, it is not going to stay still for 5 micro sec. That means that when I issue the command to open the sample and hold switch and start a conversion, the A/D amplifier is still going to be settling while it is converting the first couple of bits. That will produce bad data, but I cannot estimate how bad. I could not find any spec on what frequencies or slew rate this A/D can handle. If I have to add an external sample and hold it is going to kill some of the appeal of using this "all in one" chip.
    Robert Hoolko
